X-10/bs2sx — Parallax Forums
X-10/bs2sx
edited 2003-04-09 02:32 in General Discussion
Ok, I am using the BS2SX module along with the X-10 PL513 interface to send X-10
signals. I have the Activity Board which has the RJ-11 phone jack already on
the board. When I use the stamp in this manner, it sends the X-10 signals
fine...the light blinks on the PL513 and the command is carried out. When I
take the BS2SX off of the board and manually wire it up, and I bought a lil
phone jack(4-pin) and wired it up, it sends the signal, or at least the light
blink on the PL513 like it does when the IC is on the board, but the commands
are never carried out. It works fine with the RJ-11 jack on the board...lights
on/off, etc. But it's not working properly when I take the IC off of the board.
Could someone help me out with this problem?
Now unto Him that is able to do exceeding abundantly above all we ask or think .
- Ephesians 3:20
Nothing grows on the mountain top.......everything grows in the valley
    edited 2003-04-08 12:28
    Are you *sure* have the zero-crossing and data pins wired correctly (ie:
    not reversed) ?
    Are you plugging the PL513 into the same outlet as before after you have
    wired it up manually?
    X-10 signals. I have the Activity Board which has the RJ-11 phone jack already
    on the board. When I use the stamp in this manner, it sends the X-10 signals
    Brian <stamp@k...>
    edited 2003-04-09 00:40
    In a message dated 4/8/2003 4:37:46 PM Pacific Daylight Time,
    the_prettiest@h... writes:
    > Yeah, I'm pretty sure. I tried the different wirings and I also changed my
    > code around just to see if it would send. I'm not using the same outlet.
    > There's an outlet built into the activity board that I use, it works
    > properly when I put the stamp into the board. What doesn't work is the
    > outlet that I got from Radio Shack. I take the stamp off of the activity
    > board and wire it up manually, then I wire this new outlet to the stamp
    > The
    > PL513 light blinks, like it normally does when sending a signal...but for
    > some reason I noticed it blinks twice on each signal sent, but it does
    > blink. The other outlet is already prewired to the board, and it works
    > fine. Can anyone tell me what the problem may be?
    If everything is working normally on your board, then you remove the devices
    to your home built board, chances are there is something not wired correctly,
    even though you have probably checked, double checked and triple checked the
    layout.
    I know that is now what you wanted to hear, but that is the likely reality. I
    have done it several times myself.
    board and wire it up manually, then I wire this new outlet to the stamp The
    Sent: Tuesday, April 08, 2003 4:28 AM
    Subject: Re: [noparse][[/noparse]basicstamps] X-10/BS2SX
    > not reversed) ?
    send X-10 signals. I have the Activity Board which has the RJ-11 phone jack
    already on the board. When I use the stamp in this manner, it sends the
    X-10 signals fine...the light blinks on the PL513 and the command is carried
    out. When I take the BS2SX off of the board and manually wire it up, and I
    bought a lil phone jack(4-pin) and wired it up, it sends the signal, or at
    least the light blink on the PL513 like it does when the IC is on the board,
    but the commands are never carried out. It works fine with the RJ-11 jack
    on the board...lights on/off, etc. But it's not working properly when I
    take the IC off of the board. Could someone help me out with this problem?
    > Brian <stamp@k...>
