No Stamp Found
Hi All, I saw another post on this topic but it didn't seem to go far.
I just got back into the Stamp scene, dusted off the prototype
station and hooked up with my laptop. No Stamp Found.... The stamp
(BS2-IC circa 1998/99) still has my last program in memory and
otherwise appears to be running fine.
What's new with my setup is that I am using a Toshiba laptop with the
latest Stamp application in Windows XP Pro. I have configured the
program (Stamp v2.0b1) to use COM1 (COM3 is my modem) - the program
detects the loopback and nothing else. I have bypassed the original
serial cable with a new one, so I think that part is fine - even
changed the power supply. Is there any known issues with newer PC
hardware/software that I should address. The last time I had working
communications was with an old DOS 386 which I no longer have.
Serial FIFO is 'too high'. In Control Panel, System, Serial Devices,
Com devices, Advanced -- either disable FIFO, or reduce FIFO to 0.
--- In basicstamps@yahoogroups.com, "ii_awesum" <ii_awesum@y...>
far.
stamp
the
original
working
> Thanks,
> Mike
laptop and, just before I installed the stamp IDE, someone answered a
previous question about having to disable it on a Toshiba to get the
communications with the stamp going. I did the same, and it's worked for
me. On NT, FIFO is an advanced setting for a COM port.
I never tested with FIFO enabled.
hth
From: ii_awesum [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aiXgFxL0gR9XyDBfCe0cfyi5gd37vAtfFBLS2XmSAV5N6TkLDpKAKRqPVHZbCVwNTtEsxzmCWpC5eaS0iA]ii_awesum@y...[/url
Sent: Monday, April 07, 2003 7:26 AM
Subject: [noparse][[/noparse]basicstamps] No Stamp Found
