Laptop LCD Display Panel — Parallax Forums
edited 2003-04-08 01:25 in General Discussion
Learned colleagues;
My Toshiba 1519CS Laptop passed away recently, and after services an autopsy
was performed to see if it was a candidate for the Organ Transplant Program.
Unfortunately, the only candidate seems to be the color LCD display.
Since my knowledge of LCD video display borders on the infinitesimal, is
there any economically feasible way to use the display with any of the Stamp
modules I have going. Even a 4 x 20 character display would be fantastic.
If it helps, the LCD panel has a 2 x 10 female header and a 2 x 5 female
header, plus a ground lug.
Or should I just forget it?
Sid
    edited 2003-04-07 22:36
    Sid,
    While I'm not sure, I would bet against the use of it unless you can track
    down pinouts and the appropriate controller for the lcd. My guess is that the
    2x5 header is for lcd power, contrast, brightness, and power for the ccfl tube
    that no doubt lights it. The 2x10 is most likely where you need to look to
    actually pass the LCD data. I know you can buy a controller at some insane cost,
    and even that wouldn't afford you very much functionality.
    Shuck
    --- In basicstamps@yahoogroups.com, Newzed@a... wrote:
    > Learned colleagues;
    > Sid
    Hi Sid,
    I don't want to sound negative, but give it up. I work
    for a repair depot and one of our departments is
    laptop repair. LCD panels are exceptionally complex
    involving critical timing issues, equally complex
    bit-patterns and RGB data, tight voltage requirements
    (since you didn't describe two silicon (for the
    high-voltage CCFT back-light) wires, I can assume the
    3KV driver board is internal to the display) for the
    logic and back-lighting, and are not very tollerant of
    noise. When they work, they are wonderful and
    dependable. Unfortunately, it takes the chip and board
    manufacturers a lot of effort to make that happen.
    Last, but not least, typical signals driving LCD
    panels run into the dozens of KHz range over a 32 bit
    pattern, something you wouldn't get from even multiple
    stamps.
    Great thought, though!
    DrDiode
    --- Newzed@a... wrote:
    > Learned colleagues;
    > color LCD display.
    > Sid
    > removed]
    > from the same email address that you subscribed.
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
    http://platinum.yahoo.com
