how to calculate percentage — Parallax Forums
edited 2003-04-06 04:22 in General Discussion
Hi, I am trying to calculate a percentage. How do I keep decimals places?
ie. I want to display something like 68/90 * 100. as it is now, i always get 0.
Thanks in advance.
    edited 2003-04-06 04:16
    Change your math so that it goes like this:
    69 * 100 / 90
    You will end up with 76 due to integer division. Just be careful that you
    don't have any intermediate results that go past 16 bits (65535) -- this will
    cause problems.
    -- Jon Williams
    In a message dated 4/5/2003 8:35:13 PM Central Standard Time,
    mh_coelh@a... writes:
    > get 0.
    edited 2003-04-06 04:21
    In a message dated 4/5/2003 6:35:26 PM Pacific Standard Time,
    > get 0.
    > Thanks in advance.
    6800/90 = 75.5, but the stamp will return 75, or 76 (cant remember).
    If I remember correctly, the stamp will return only integer values.
    If you need more resolution, 6800/9 = 755, then you will need to "pick off"
    each digit to get 75.5.
    There is probably a more elegant solution and as there are many very helpful
    people in this forum, I am sure you get the information needed to solve your
    current delima.
    Try redoing it like this:
    68*100/90
    Just make sure that 68*100<65535
    Al Williams
    AWC
    * Floating point math for the Stamp, PIC, SX, or any microcontroller
    http://www.al-williams.com/awce/pak1.htm
    > From: mh_coelh@a...
    > [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fewKG-5AJ81jFUWlWyGRWp-tADnR4G4V9DpHsOS1ymS1hYRcCjG_tazHb3URW_plWQqH5km7lF17BkB2OOuF4kj-pIW1aA]mh_coelh@a...[/url
    > Sent: Saturday, April 05, 2003 8:34 PM
    > Subject: [noparse][[/noparse]basicstamps] how to calculate percentage
    > decimals places? ie. I want to display something like 68/90 *
    > Thanks in advance.
    > from the same email address that you subscribed. Text in the
