Serial com. probs w/ bs2sx and CMUCam
hi, I finally got my stamps (bs1 and a bs2sx) working thanks to help
from you guys. Thanks a lot. Now I'm trying to integrate the bs2sx
with a cmucam (not modified by parallax). I'm having trouble sending
and receiving serial data between the bs2sx and the cmucam. This is
what I have done so far:
1)I couldn't find the jumpers so I just wired the appropriate pins on
the cmucam together to set up for 9600 baud rate ('jumper 2'
and 'jumper 3').
2) I've wired bs2sx pin 6 to the RX pin on the cmucam (within the
cmucam's 'ttl serial' pin group),
wired bs2sx pin 7 to the TX pin on the cmucam(within the
and wired the bs2sx GND pin to the TTL serial GND pin on the cmucam.
3)The cmucam and bs2sx are powered seperately (red led on cmucam is
on, and I'm able to download to the bs2sx).
4)I've tried the following code with the 'MAX232' chip in and with it
out of its cmucam socket (I read in the cmucam documentation that it
might be necessary to remove it for ttl serial communication).
In running my code below, the cmucam tracking (green) LED does not
turn on as I tell it to. If I do a serin 6,240,[noparse][[/noparse]wait (":")] after the
serout, the program stalls at this point (the : is never received). I
have tried the suggestion of someone on this mesage board to put the
serin in a seperate subroutine to 'get the timing right' and this has
not worked either. Could you give any suggestions? My code is below
(the 13 is ascii for cr):
When I run this code, the green cmucam LED doesn't turn on.
main:
debug "init"
serout 7,240,[noparse][[/noparse]"L1 1",13]
'goto GetInfo
debug "after"
end
GetInfo:
return
and 'jumper 3').
main:
debug "init"
'goto GetInfo
debug "after"
end
GetInfo:
return
Is the CMUcam's demo-mode jumper still in place on the Level Shifted Serial
Port?
Is the CMUcam's Programming Switch in the OFF position?
Is it possible that you have overlooked the fact that pins labeled P6 and P7
(used by the SERIN & SEROUT) are not the 6th and 7th pin on the Stamp, but
are the 11th and 12th pin?
When you say you are "able to download to the BS2sx", you mean that you can
program the Stamp from your PC, correct?
HTH,
Daniel
Sent: Saturday, 05 April 2003 21:19
Subject: [noparse][[/noparse]basicstamps] Serial com. probs w/ bs2sx and CMUCam
> and 'jumper 3').
> main:
> debug "init"
> 'goto GetInfo
> debug "after"
> end
> GetInfo:
> return
