Basic analog and digital conversion projects — Parallax Forums
edited 2003-06-20 04:21 in General Discussion
Have you tried another POT? The current one may be noisey?
--- In basicstamps@yahoogroups.com, Hudson T Clark
<dark_archon1@j...> wrote:
> I have this stuff I'm doing for school and this one project that
has you
> make a DVM with the basic stamp and lm0831 A/D chip... Ok I
got
> everything to work and I finished all the challenges... The
problem is in
> the decimal display of the debug window sometimes there is a
glitch and
> for example when I'm rolling over to exactly 1v it will glitch and
show
> 2v... Its a little buggy when I move the POT around a lot like this
it
> will do it for other values to... I was just wondering is this just
an
> instability of the basic stamp or am I screwing something up?
Has anyone
> else experienced this? Can someone give me any input to
what the problem
> could be?
    edited 2003-04-05 14:49
    It is probably the potentiometer your using. The wiper can be what they call
    noisy, and it'll have jumps or irregularities in the readings.
    Your program is OK. But you could possibly modify it to compensate for the
    flaky pot by taking three readings from the ADC and average them, or take
    three readings, throw away the most out of range one, and average the other
    two. Depending on your program you could take 4-5 readings and throw away
    the worst one and average the others as well.
    Another approach would be besides taking multiple readings is to track
    whether the pot is turning left or right, from previous readings, and to
    ignore (at least momentarily) the first few irregular readings that have it
    look like it's moving in the wrong direction.
    From: Hudson T Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Fp9wTI3lDgfln49mknHyF--sNTuZBmGK51x3fkUqmawcgSRoxlnlW4PArG5B7Y-ffEtKhebgdxD-kVygk9gh]dark_archon1@j...[/url
    Sent: Monday, June 16, 2003 4:01 AM
    Subject: [noparse][[/noparse]basicstamps] Basic analog and digital conversion projects
    I have this stuff I'm doing for school and this one project that has you
    make a DVM with the basic stamp and lm0831 A/D chip... Ok I got
    everything to work and I finished all the challenges... The problem is in
    the decimal display of the debug window sometimes there is a glitch and
    for example when I'm rolling over to exactly 1v it will glitch and show
    2v... Its a little buggy when I move the POT around a lot like this it
    will do it for other values to... I was just wondering is this just an
    instability of the basic stamp or am I screwing something up? Has anyone
    else experienced this? Can someone give me any input to what the problem
    could be?
    edited 2003-04-05 17:58
    What about a cap and resistor set-up similar to the pwm output
    circuit? wouldn't it average the readings and eleminate much of the
    noise ?
    also, is the pot a multi-turn? I found that using old parts
    sometimes have problems.
    Dave
    --- In basicstamps@yahoogroups.com, "Earl Bollinger"
    they call
    for the
    or take
    the other
    throw away
    track
    and to
    have it
    > From: Hudson T Clark [noparse][[/noparse]mailto:dark_archon1@j...]
    has you
    is in
    and
    show
    it
    an
    anyone
    problem
    > could be?
    Subject and
    edited 2003-04-05 22:31
    Hudson:
    In the case of a pot, it isn't distortion, per se. Instead its the result of
    grinding. Most pots are either wire-wound (a bobbin with resistance wire
    form wound onto it) or carbon (a cylinder or disc). In either case, a
    suitable "wiper" (the center tap in a schematic with a pot in it) is used to
    slide around or over the surface, under a slight spring tension. In the
    event that the pot surface, or the wiper surface, or both, oxidizes (happens
    constantly, its why solid state volume controls, DAC based, or using active
    op-amps, are so popular in audio gear), the noise factor rises when you move
    a pot, and as the spring tension on the wiper ages, the wiper starts making
    microscopic bounces (more noise), and your readings all go bad (or your ears
    hurt worse).
    Mic
    See what weird things you can learn in the US Navy?
    Cc: <basicstamps@yahoogroups.com>
    Sent: Monday, June 16, 2003 5:14 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Basic analog and digital conversion projects
    > Yeah thats what everyone is saying, it didn't pop into my head I didn't
    > think a POT could be noisy... but it makes sense... I know what "noise"
    > is its unwanted distortion that messes up your signal. =)
    edited 2003-04-06 04:19
    Ah. Was navy. Are not now. Been out for over 20 years (CTM1, out in March of
    1982. Electronics never dies, though!) So I'm not sure what book you refer
    to, but would like to know. I always found the level of detail in Navy
    training to be better than any of the other services, with apologies to
    those in the other services. But I did attend courses taught by the USAF,
    USN, and the US Army, and I still thought the Navy was best for quality and
    depth of detail.
    Mic
    Sent: Monday, June 16, 2003 6:43 PM
    > Oh ok yeah maybe I didn't use the correct words but I understand what is
    > going on. Btw if you are in the navy I like that navy electronics book
    > they have... I forget what its called but that thing is a nice reading
    > for anyone interested in electronics. =)
    edited 2003-04-07 01:51
    Its kind of a surprise to me that they still go down to molecular physics to
    get you into basic electronics, but it is precisely that attention to, and
    level of detail that made me like the Navy electronics courses I took so
    much. One of the things impressed on us even then was that if you don't have
    a component, be it a resistor, or capacitor, or whatever, and the ship is in
    dire need of that precise piece of equipment to be able to work, a pretty
    little commercial unit is not near as necessary tomorrow as a big ugly kluge
    is today, so we'd better be able to make it from literally ANY piece of junk
    laying around. And understanding molecular physics, and a modicum of math to
    use with that knowledge, let us design caps from really weird stuff, like
    cling-film, aluminum foil, and paper clips, and actually be able to
    calculate its value before building it, leaving only the need to squeeze the
    roll gently in order to fine tune it. We also made a makeshift television
    reciever out of two broadband RF recievers and an oscilloscope. Great fun,
    that theory, but we did that while I was overseas, and just cause we wanted
    to. But it did prove my point about the Navy's educational materials being
    the best available, if you just apply the knowledge.
    Mic
    Sent: Tuesday, June 17, 2003 1:31 AM
    > I can't really remember and I looked threw my IE history I couldn't find
    > it, but I think its like the basic electronics one they make people read
    > maybe it goes over like all the basic stuff... like resistor networks,
    > they even had like some nuclear stuff I think???
    edited 2003-04-09 02:05
    True. And I hope you didn't think I was denigrating that level of detail.
    Knowing that has helped me in too many ways, since I never really got out of
    the sciences. I am a computer geek now, and a budding robogeek, but I will
    not ever quit designing bigger and better ways to make things spark, flash,
    boom, bang, and fling potatoes and such in the air. And knowing something
    about all sorts of physics REALLY helps when you are trying to decide just
    how big a bunker you need to be in before you touch that last honking
    monster off. It also helps when I'm trying to iron the bugs out of a
    gas-turbine conversion to a Chevy pickup truck, selecting fuels, figuring
    out jetting for the turbine, finding suitable braking systems, etc.
    Life is a classroom, and only dropouts quit learning!!
    Mic
    Sent: Wednesday, June 18, 2003 12:50 AM
    > Yeah but molecular theory is needed I think anyway to understand much of
    > electronics. You need to understand what exactly electricity is to
    > understand how we are using it... I mean you can say like analogies to
    > explain how components behave but the little diagrams in most books of
    > electrons, protons, ions, etc moving around really help when
    > understanding how exactly components work.
    edited 2003-06-16 10:00
    could be?
    edited 2003-06-16 23:14
    edited 2003-06-17 00:43
    edited 2003-06-17 06:31
    edited 2003-06-18 05:50
    HAHAHA I'm a high school drop out, but its cool. I really don't have a
    lot of intellectual respect for people that go to school unless they give
    me a reason to. I go to college myself, and I have dropped out of high
    school. I started going to this community college near my house when I
    was 17 for electronics as my major. It's funny... I have a pretty dark
    past until I found out about these little buggers we call "computers" now
    I'm like most uber geek!!! It's sad sometimes I get so frustrated that
    some of my other peers are so not good at it. I hate how people believe
    that someone is smart just because a piece of paper says so. Right now
    I'm really into electronics... I also do computer programming... my web
    page is http://dark.zemos.net soon I will be releasing one project I'm
    working on called CGI::Marijuana which is a massive content loader module
    for perl (think of every CGI script you have ever seen all in one perl
    module =). It's funny a high school drop out can accomplish so much. I
    have never taken a programming class in my life and I have a good feeling
    I can probably code better then the graduates from my school. Not saying
    I'm smarter then everyone just most of the people I have encountered at
    school. I know for a fact that many people exist that know an insanely
    large amount more so then me. =)
    But it is so much to ask for some common sense? You know I bet you
    wouldn't believe it but I have experienced students arguing on steps
    behind the physics building about what an "if" statement does. i.e.:
    if(1) {
    do this heh
