Top urgent
To: Gehard Mendis
Cc: hhlim@w...
Sent: Friday, April 04, 2003 3:08 PM
Subject: Re: TOP URGENT
Dear Gehard,
I think Speedcom is point-to point radio system which carry E1 from one point
to another.
But what we require is similar to SpeedLan 9000 (Point to Multipoint) , One
Central Base Station with E1 port, and Remote CPEs(about 30 per base)s with
Serial or Lan ports to connect to Base Stations.
Nilaweera.
> Subject: TOP URGENT
> >Hi Gehard,
> >By the way, if their requirement is E1 port, the solution is SPEEDCOM
> >available in E1, 2xE1 and 4xE1.
> >Regards,
> >HH.
> >From: HH Lim [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=n6TiMQhGh7jYMwK0nAHjODwYFRcpOmSSqquAkmm0Nz0niA0RF2cuUM4Zf0RMUrva-hLsPSaa7MGeXIseOyM]hhlim@w...[/url
> >Sent: Thursday, April 03, 2003 12:31 PM
> >To: 'Gehard Mendis'
> >Cc: 'Richard Chew'
> >Subject: RE: TOP URGENT
> >Hi Gehard,
> >Routers for conventional leased line have E1 port (2Mbps or fractional) for
> >WAN. The other port is usually Ethernet for LAN connectivity. IP routers
> >have Ethernet for both WAN and LAN, and are much less expensive than
> >conventional routers. We need to understand the actual application. If
> the
> >end objective is connecting LANs, then there is no needs for conventional
> >routers. Unless they requirement is for connectivity to PBXs.
> >By the way, SPEEDLAN 9000 are routers!!! which mean you don't need
> >additional router and it can be connected directly to switches and hubs.
> >Please check with customer regarding their applications, and if possible
> >provide us with a diagram on their requirement.
> >Regards,
> >HH.
> >From: Gehard Mendis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KWOwoPP2mbWXHxvzIGVE5cqISeDfD57XRqzmIzPHc_n8V8uuXyi_vBcfM9RP-jENmPR7gRoC_mk]gehard@s...[/url
> >Sent: Thursday, April 03, 2003 10:51 AM
> >To: HH Lim
> >Subject: TOP URGENT
> >Dear Lim,
> >We quoted one of the project your SpeedLan 9000 series base stations/CPE
> >etc. Butat the Radio Base station end radio will have to be connected to a
> >Router with E1 port. SpeedLan descriptions you send me has only the
> >10/100Base-t (LAN)port to connect to router.
> >If you have any Radio product with E1 port at the Base Station (which then
> >can be connect to a Router with E1 port), please send me the
> >description/prices etc.
> >Raply as soon as possible.
> >Thanks,
> >Gehard.
> >From: HH Lim <hhlim@w...>
> >To: 'Gehard Mendis' <gehard@s...>
> >Date: Friday, March 28, 2003 12:03 PM
> >Subject: HS Code
> >>Hi Gehard,
> >>The HS Code is 8471.80.9100
> >>Regards,
> >>HH Lim
> >>Director, Asia Pacific and China
> >>Wave Wireless Networking
> >>a division of SPEEDCOM Wireless Corporation
> >>hhlim@w...
> >>www.wavewireless.com
> >>Tel: +65.6464-9283
> >>Fax: +65.6769-0966
