Keyboard output to multiple PC''s with the stamp?
So, Al. Apparently a keyboard's clock rate is approx. 10-20 KHz.
Your understanding is that I should be able to fire the clock pin at
a slower rate I can control with my BS2 and the PC should accept it?
The PC doesn't have any kind of timeout? If so, this doesn't look so
bad at all.
I found a good FAQ here:
http://www.repairfaq.org/filipg/LINK/PORTS/F_Keyboard_FAQ.html
If the PC will accept keyboard data at my pace, it sounds like all I
need to do is watch for it to be ready for data, then use the clock
pin to send scan codes and key codes.
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> > I'd LOVE to see the CNC solution though. Think of all that lovely
> > movement! And the 'clicky-clicky' sound!
> As you know, the PAK-VI is the other way around. It should be
possible
> to "fake" a keyboard with the Stamp since the keyboard (or Stamp, in
> this case) sets the clock rate. Going the other way is what's tough
> because you have to keep up with the keyboard's clock.
> However, if you like clicky clicky, have a look at what a student
did
> with a PAK-VI and a Basic Stamp a while back:
> http://stage.itp.tsoa.nyu.edu/~jn429/robotictype/index.html
> Click on technical to see the insides.
> Al Williams
> AWC
> * Control 8 servos at once
> http://www.al-williams.com/awce/pak8.htm
bad at all.
possible
did
> Al Williams
> AWC
