a/c circuit transient suppression
Hi David,
Try using two V47ZA1 varistors (or the equivalent), one across the
solenoid coil and the other across the output of the 24VAC transformer.
Also, put a 0.1 muF 50V ceramic capacitor across the output of the
transformer, and (what the heck) across the input of the transformer put
a V130LA20A varistor.
cheers,
Bill Porter
> Here's the situation: I've got a bs2 controlling a 5vdc relay which switches a
24vac sprinkler valve controller. The power supply for the whole setup is a
24vac transformer; I'm using a bridge and regulator to cut it down to 5vdc for
the electronics (with lots of filter caps) and it also powers the valve selenoid
directly via the relay. I've got a rectifier across the relay coil to clamp
spikes, but I have a feeling I need something across the selenoid (something
called a snubber, perhaps?) to block spikes generated by it during switching.
The system behaves somewhat irratically when the selenoid is switched on and off
(scope -- set for a/c, 2v/div -- seems to show occasional spikes during the
switching), it behaves fine without the selenoid, and also with the selenoid if
I put a cap across it (probably not a great idea since it's driven by a/c).
I'm not that familiar with a/c circuit transient suppression, and would
appreciate any insights.
cheers,
Bill Porter
