a/c coil transient suppression — Parallax Forums
edited 2003-04-07 18:04 in General Discussion
Hi folks,
I'm new to the group and to stamps, so thanks in advance.
Here's the situation: I've got a bs2 controlling a 5vdc relay which switches
a 24vac sprinkler valve controller. The power supply for the whole setup is
a 24vac transformer; I'm using a bridge and regulator to cut it down to 5vdc
for the electronics (with lots of filter caps) and it also powers the valve
selenoid directly via the relay. I've got a rectifier across the relay coil
to clamp spikes, but I have a feeling I need something across the selenoid
(something called a snubber, perhaps?) to block spikes generated by it
during switching. The system behaves somewhat irratically when the selenoid
is switched on and off (scope -- set for a/c, 2v/div -- seems to show
occasional spikes during the switching), it behaves fine without the
selenoid, and also with the selenoid if I put a cap across it (probably not
a great idea since it's driven by a/c).
I'm not that familiar with a/c circuit transient suppression, and would
appreciate any insights.
thanks,
d...
* David Okagaki dokagaki@w...
* "The light at the end of the tunnel is that of the on coming train!"
    edited 2003-04-04 13:19
    I would use a CRYDOM solid state relay with ZERO CROSS switching instead of
    a relay.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2519525232&category=4660
    From: Dave [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h2HCuSmPcRsLm8vBu2tnmg70CTzTEx9Vk41tejuVTr9zPech6kWNIaQSipYh_ugGsB6-4GdYpHyjqXdvbEjHtnbg]dokagaki@w...[/url
    Sent: Friday, April 04, 2003 12:53 AM
    Subject: [noparse][[/noparse]basicstamps] a/c coil transient suppression
    Hi folks,
    thanks,
    d...
    edited 2003-04-04 15:16
    Dave,
    When you wish to suppress noise or switching transients with AC solenoids,
    the best devices I have found are the Panasonic ZNR transient/surge
    absorbers. Mount one across the solenoid. You must select the proper one
    based on applied voltage and application. Check out digikey.com for
    information. If you want to use relay switching, just control a standard
    relay which will handle the current at the ac voltage you are using with a
    transistor switch. Use the ZNR suppressors across the solenoid coil and a
    diode across the relay coil to suppress switching transients or you could
    switch a solid state ac relay such as a crydom D1210 (for 120vac @ 10 amps)
    or crydom d2410 (for 240vac @ 10 amps). The crydom relays require 3 to 32
    volts dc to switch. I recommend using a transistor switch between the stamp
    and the crydom relays.
    For control configurations using a stamp and transistor switching, check my
    web site.
    Jim
    http://www.geocities.com/jimforkin2003
    From: James R. Parish [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uO2Gh1kYkdFlDl6IhPSY6Sg3pZTkoYFGTZBTDyHwikEmdVCK5qij6RXABUUfJl5hSv2pDbGdeLeN-1omvYhq5Q]JamesParish@J...[/url
    Sent: Friday, April 04, 2003 7:20 AM
    Subject: RE: [noparse][[/noparse]basicstamps] a/c coil transient suppression
    a relay.
    From: Dave [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hVc_SEPt6yv254A0sgKJWzOfOyB-g2NDWuUAmVT1noTztO_gDYruWJPD1Egq05C8xil5lXjx3J6U_Ig1B_JN5xM]dokagaki@w...[/url
    Hi folks,
    thanks,
    d...
    edited 2003-04-04 18:55
    hi i would look for a dc to dc converter there are
    some with up to 20v in with a regulated 5v out most
    of these are a switching type were the output is
    totaly isolated from the input should take care of any
    noise problems from the valve coil
    --- Dave <dokagaki@w...> wrote:
    > Hi folks,
    > advance.
    > -- seems to show
    > fine without the
    > thanks,
    > d...
    > * David Okagaki
    > dokagaki@w...
    > on coming train!"
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Tax Center - File online, calculators, forms, and more
    http://tax.yahoo.com
    edited 2003-04-05 16:56
    just as an update, I scrounged a MOV from an old powerstrip and used that
    across the selenoid. seems to work great along with the extra filtering.
    thanks to everyone who replied!
    d...
    > From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e6lLFSv1uC9o9p3baTS0zxGnS3ETkl99ZzSoX1Q_Qxdr62tpVL7pU3hxnNEMrBlzVBJv66fH19IM]jjf@p...[/url
    > Sent: Friday, April 04, 2003 6:17 AM
    > Dave,
    > @ 10 amps)
    > between the stamp
    > switching, check my
    > web site.
    > Jim
    > From: James R. Parish [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rSquM15PiQPtQ-lPhGmwsl43VegEUqZnT2pQ8GzMNCu_K37G69zBG6HG7STteOCpoliMcb4-crZsrXwQog]JamesParish@J...[/url
    > instead of
    > a relay.
    > gory=4660
    > From: Dave [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZwR8hbq_xICkM79yvSVGF3HJopmNzPq5x8cGdm9_iXNRujFYXf9uUvkL5dSI4UuliNyfmqKf_Wnk_tgUYyyn]dokagaki@w...[/url
    > Hi folks,
    > which switches
    > whole setup is
    > down to 5vdc
    > the valve
    > relay coil
    > the selenoid
    > (probably not
    > thanks,
    > d...
    edited 2003-04-06 00:59
    You have to watch out for MOV's. They have a lifetime issue. When they stop
    working you don't know it until something else fails.
    A better solution is to put a snubber in parallel with the coil. A snubber s
    just a cap and resistor in series. Put this in parallel with the coil.
    Typical values are .22uf cap and 100 to 1k ohms for the resistor. Use 1/2 to
    1 watt resistors. The values will vary depending on the voltage and current
    draw of the coil.
    If the resistor you are using gets warm try a larger value.
    Check out Allied Electronics for pre built Snubbers.
    <A
    HREF="http://www.alliedelec.com/catalog/pf.asp?FN=159.pdf">http://www.alliedelec\
    </A>
    They are pricey, but are a single unit.
    Good Luck,
    Alan Bradford
    Plasma Technologies
    MOVs tend to short out when they die. This is a good indicator, but can
    be a problem if the fuse isn't in the right place<G>. I have used back
    to back zener diodes, and/or transorbs (zener diodes made specifically
    for surge protection. But a snubber is excellent, and likely you have
    one in your box. Try one, put an oscilloscope across the line and see
    how it does<G>.
    From: plasmastamp@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OUlq1qdlHqohzjqaInVuE7Mapy5gtlT_4OwjedgIPPkLJyHDD_4T-IPqZQeaD4KOolrf8bXlGtILKw]plasmastamp@a...[/url
    Sent: Saturday, April 05, 2003 6:59 PM
    Subject: Re: [noparse][[/noparse]basicstamps] a/c coil transient suppression
    stop
    snubber s
    1/2 to
    current
    draw of the coil.
    If the resistor you are using gets warm try a larger value. Check out
    <A
    liedelec.com/catalog/pf.asp?FN=159.pdf</A>
    Good Luck,
    Alan Bradford
    Plasma Technologies
