Newbie Question (mountain bike data collection)
Hello
I'm a real beginner at basic stamps, well I'm not even a beginner yet.
Im a pro mountain biker & I want to measure the bumpiness (vertical
accereration/displacement) of my bike as I ride (with the view of optimising
tyre and suspension settings to get a smoother (=faster) ride).
I have a sensor (home made arrangement of foam springs, magnet and hall effect
sensor,
www.timvincent.co.nz/sensor.jpg if anyone knows where I might find something
better that is also cheap I am interested). I'm doing some testing using a
device that allows me to capture analog voltages through the parallel port of my
laptop.
Riding with my laptop strapped to my back isn't a long term option. So I'm
looking for an alternative, commercial dataloggers i've found are either too
big, too expensive or too slow (sample rate).
I am interested to know if a basic stamp can do the job. From what I have read I
can measure the analog voltage output of my sensor and save the data on the
EEPROM of the stamp.
Can anyone tell me what sort of sampling rate I could achieve, how much data I
could store (can I add more memory) and is there likely to be a program already
written that I could modify for this purpose.
Also what kind of setup would work best. In the couple of days that I've been
reading about basic stamps I've only been confused by the wide range of info,
boards, chips brands etc available.
Any advice much appreciated.
Tim Vincent
sensor,
laptop.
Tim Vincent
but it is possible to add one as a separate chip. Well, it is not
fair to say that the Stamp does not have an built-in ADC, because for
some signals the PULSIN or RCtime or COUNT commands can serve that
purpose. Those are probably not suitable for your clever Hall
effect/magnet sensor, though. Look through the archive here and you
will find references to the Analog Devices accelerometer, and at
Parallax you will find their new Memsic accelerometer. Those will
have quite a high frequency response.
As to sample rate, with the Stamp you might get up on the order of
100 samples per second, but not too much faster than that. The Stamp
runs interpreted PBASIC, which is relatively slow. That rate might
be enough for your purpose, if the sensor is damped and the really
high frequencies don't matter. In any event, you will not be able to
store data at that rate in the Stamp's own memory. There is not
enough RAM for many samples, and the eeprom is slow (several
milliseconds to burn a byte.). You could pre-reduce the data and
occasionally store average values, minimum, maximum, etc. You could
conceivably store larger amounts of data in an external memory chip,
and then offload that for post-processing. The Stamp does not have
enough memory and horsepower to do things like DFTs in situ.
-- regards,
Tracy Allen.
mailto:tracy@e...
http://www.emesystems.com
>Hello
>optimising tyre and suspension settings to get a smoother (=faster)
>ride).
>hall effect sensor,
>something better that is also cheap I am interested). I'm doing some
>testing using a device that allows me to capture analog voltages
>through the parallel port of my laptop.
>So I'm looking for an alternative, commercial dataloggers i've found
>are either too big, too expensive or too slow (sample rate).
>have read I can measure the analog voltage output of my sensor and
>save the data on the EEPROM of the stamp.
>much data I could store (can I add more memory) and is there likely
>to be a program already written that I could modify for this purpose.
>I've been reading about basic stamps I've only been confused by the
>wide range of info, boards, chips brands etc available.
>Tim Vincent
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
very easy to interface and use. It's an 8-pin DIP -- and in
fact Parallax has an app-mod on their site for it to get started.
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> The Basic Stamp does not have a built-in analog to digital
converter,
for
you
Stamp
to
chip,
> -- regards,
> Tracy Allen.
> mailto:tracy@e...
> >Hello
yet.
(vertical
(=faster)
> >ride).
> >hall effect sensor,
find
some
option.
found
I
likely
purpose.
that
the
> >Tim Vincent
