Dial encoders and Basic Stamps
Archiver
Ciao,
I'm looking for a solution to a problem: I need to interface a dial rotary
encoder (2-bit quadrature) to my BS2 so that I can vary some parameters (up and
down)that are displayed on a LCD.
I found something in the web, involving a two-states array and the lookup
statement, and it works, but at too slow speeds of my 50-steps encoder. And with
no accuracy.
Now I'm turning towards an absolute 8-bit encoder, but if somebody has the trick
in his pockets, please send an info.
Thanks in advance,
Alberto.
no accuracy.
Thanks in advance,
Alberto.
Please refer to "Nuts and Volts" column #8 for the answer to your problem. I
have been using this technique to control various ham radio equipment and
have found it to be very reliable.
Good luck.
KD6MZU
From: Alberto Calderara [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5pyCsfyznMDR_gxzdJ0fAMwOZUhc-dEWR8uGF1TOWW90_-NZlP41aBV5C4JSs_G6N-H4ZQHnqmsm0eSy0Ewu4C-s6N400YM]albertocalderara@t...[/url
Sent: Thursday, April 03, 2003 9:50 AM
To: Basicstamps group
Subject: [noparse][[/noparse]basicstamps] Dial encoders and Basic Stamps
Ciao,
and down)that are displayed on a LCD.
with no accuracy.
trick in his pockets, please send an info.
Thanks in advance,
Alberto.
Alberto, IZ2EWV.
Sent: Friday, April 04, 2003 5:35 AM
Subject: RE: [noparse][[/noparse]basicstamps] Dial encoders and Basic Stamps
> Alberto,
I
> Good luck.
> KD6MZU
If it will help I will forward to you the code I have developed to read
rotary encoders and dispatch program control. The speed at which the stamp
can access I/O limits the usability of rotary encoders to about 1 quadrature
pulse every 10 degrees (in my current application), which I have found to be
more than adequate. When this code is placed within an event loop and is
part of the routine event service, even 1 quad pulse is functional since the
stamp remembers the state of the last sample.
One of my applications calls for two encoders and 6 switches. The stamp has
NO problem servicing both encoders, even while there are other events to
service.
Good luck.
KD6MZU
From: Alberto Calderara [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_UaZ9SQZBlnqhCW2Or8JTCdWh-2TEjxS0y1WKYh9vFhKhCvXwA9uP2FdPrg6i_3tGLV3a7qaY0kgNAWAwtWBj1wKLwA]albertocalderara@t...[/url
Sent: Sunday, April 06, 2003 8:40 AM
Subject: Re: [noparse][[/noparse]basicstamps] Dial encoders and Basic Stamps
Thanks Leland for the info, I will try that solution.
Alberto, IZ2EWV.
> Alberto,
I
> Good luck.
> KD6MZU
