LCD Display for $12.50....
I'm looking for an easy connecting low cost LCD Display with
backlighting. I've come across a 2x24 LCD Display from All Electronics
for $12.50. Does anyone know how difficult this unit would be to get
running with a BS2P and the BS2P Demo Board? The display comes with a
2x7 plug which may make the header on the Demo Board.
http://www.allelectronics.com/cgi-bin/category.cgi?category=search&item=L
CD-69&type=store
Does it matter that the documentation (see link) doesn't call out a
HD44780 driver, or will make it more difficult to get working?
Any thoughts on this?
Chris
________________________________________________________________
Sign Up for Juno Platinum Internet Access Today
Only $9.95 per month!
Visit www.juno.com
CD-69&type=store
Chris
Visit www.juno.com
current is set with resistors R11-R13 and are populated with 4.7 ohm,
1206 resistors. If you remove R9(zero ohm jumper) the backlight will
be off. You can solder wires from each pad of R9 to a switch and
control the backlight on or off. The display takes about 400 mA with
the backlight on and if you switch the backlight on or off place a
220 uF cap by pins 1 and 2 of the LCD connector on your board or you
will reset your stamp with the surge. I have changed R11-R13 to 22
ohm, 1206 and the backlight is still bright enough to see in the dark
and only requires a fraction of the current.
Here is the display on one of my projects.
http://myweb.core.com/photos/jbirnsch(at)vbe(dot)com/BasicStamp/
Replace the (at) and (dot) in the link with @ and .
Jason
Electronics
get
with a
> CD-69&type=store
> Thanks,
> Chris
> Visit www.juno.com
