COLD weather...
Hello Stampers, I was wondering if any stampers in very cold areas would be
able to help me with using an LCD outdoors at temperatures down to -40c. I
am in Australia and we never even hear of these temperatures, but I know
some of you Canadian or US people would (I dont know how) live at times in
these extremes. (I dont know why you dont move down here if its that cold !)
I have been asked to make a stamp based project which has a keypad and LCD
which will apparently be subjected to extremes of that temperature.
I have tested the unit in my deep freeze which I think only gets down to
about -20c, and the system works fine except the LCD is very slow to react.
It is useable, but if it was at -40c I dont know what would happen.
Does anyone have any tips for warming the LCD etc ?, or any other
information that may help ?.
Thanks in advance,
Chris - Western Australia (very cold today... +24c)
Thanks in advance,
do so. Here in New Jersey, we get cold, about 10deg F above zero,
but not much less (often)
A simple well insulated and heated enclosure would be wanted and in
those termpeatures, you might want to check on battery specs. An
option might be that a button press will start a warming cycle that
will heat the display for a minute while the operator waits.
another option might be a LED that responds with a push button ?
My experiance with low temperatures was with a HOBO data logger. as
it approached 25 deg F, the readings died. it resolved about 80% of
the reading in the first 5 minutes, but after a half hour, the
reading was still moving towards the actual temperature. I never
was able to monitor actual changes at temperature due to the lack of
response. I did have the electronics in 70 deg F room with a sensor
in the fridge.
My intention was to monitor the refridgerator coil cycling on an off.
When selecting a sensor, make sure that it is capable of not only
seeing the temperatures you want, but also to respond to the accuracy
you are looking for at those temperaturs and in the time frame you
need.
Dave
--- In basicstamps@yahoogroups.com, "Chris Anderson" <fuel@b...>
would be
40c. I
know
times in
that cold !)
and LCD
down to
to react.
> Thanks in advance,
extended-temperature LCD. One engineer used a special heater that warmed the
inside of the cabinet, while the other designed his product to use a cheap
power resistor mounted behind the LCD. Both used a temperature sensor IC to
determine when heat was needed.
If the electronics will be exposed to people with the cabinet open, be sure
to use some sort of shield to prevent burns. Also, an LED to indicate when
the heater is on will aid troubleshooting.
> Warming the LCD should not be a problem if you have enought power to
and is one of the most inexpensive items one can buy
is a Styrofoam cooler. I used one of these with some
LCD containing instruments. When I wanted to read
the display I would insert one of those self heating
packs they sell for camping. In about 15 minutes
the enclosure was warm and the LCD worked down to -40
F.
Andy
Sent: Tuesday, April 01, 2003 15:27
Subject: Re: [noparse][[/noparse]basicstamps] Re: COLD weather...
> The equipment I used to support was designed for outdoor use with an
the
to
sure
Goldmine. They are like thick tape, and they came in a pack of different
sizes. They have sticky on the back to adhere. I haven't really played with
them, but they might make a nice LCD warmer.
Jonathan
www.madlabs.info
Sent: Tuesday, April 01, 2003 7:48 AM
> Another thing that works really well for cold temps
> F.
> Andy
> From: "Rodent" <daweasel@s...>
> the
cheap
> to
> sure
when
and
