Sttc Electricty
Archiver
Hi All
Influence from Static Electricity on the inputs, has any one had
experiences?
I am using Hall Effect switches, could it be the switch are extremely
vulnerable to static.?
Any One Please.
Regards Larry
experiences?
Any One Please.
Regards Larry
> experiences?
plate and the mount is not even connected to the power supply. I have not
had any failures.just units are changing states.
any other means. So the answer to your question is that they are no more
sensitive than any other semiconductor. Of course enough of a static
discharge can blow any semiconductor device. Infact a Hall effect device
should be better since no direct contact needs to be made to the device.
Unlike a mechanical switch that must be contacted to work!
