Problem with Stamp 2
                    hello,
i'm having a problem uploading my program to my BS2. When I press
CTRL-I to identify my stamp. I get this back: Loopback - YES
Echo - YES
but the version is not displayed. Also, when trying to upload my
program to the stamp, it displays an error message saying that it
doesn't detect a stamp. I've checked the power supply and verified
continuity in the serial cable. I can't see what's wrong. HELP! :-)
P.S. I'm using an OEM version (every thing is socketed), so if its
something in the stamp I can replace any of the chips.
Brian Edmonson
Echo - YES
Brian Edmonson
I had some of the same sort of trouble. My problem was I had miswired a
device that was connected to the BS2. When I fixed the connections, I was
able to communicate with the stamp.
Good Luck,
Art
"Brian"
<be068095552@y To: basicstamps@yahoogroups.com
ahoo.com> cc:
Subject: [noparse][[/noparse]basicstamps] Problem with
Stamp 2
03/26/2003
04:06 PM
Please respond
to basicstamps
hello,
Echo - YES
Brian Edmonson
to the module. I just wanted to get the program in the memmery.
Then later connect the other electronics.
-Brian
--- In basicstamps@yahoogroups.com, arthur_schoenborn@a... wrote:
> Brian,
miswired a
connections, I was
> Good Luck,
> Art
> "Brian"
> <be068095552@y To:
> ahoo.com>
cc:
> Subject:
[noparse][[/noparse]basicstamps] Problem with Stamp 2
03/26/2003
> 04:06
PM
> Please
respond
> to
basicstamps
> hello,
> Echo - YES
HELP! :-)
> Thanks,
> Brian Edmonson
Subject and
few interesting results while testing my BS2P. If the line to pin 3
of the Stamp (ATN) is open you will get a yes to loopback and echo
but no Version or ID. Now here is the weird part. An unpowered stamp
will also give the same result. I just double checked again and sure
enough, my BS2P with nothing attached but the serial cable, no power,
responds with Yes to Loopback and Echo. But no Version or ID.
--- In basicstamps@yahoogroups.com, "Brian" <be068095552@y...> wrote:
> hello,
> Echo - YES
> Thanks,
> Brian Edmonson
I assume you are using the V2.5 software. I had a similar problem and thought
it was the Stamp 2p that I had just purchased.
The Stamp-2' all worked OK, but the 2p would not get recognized, but had
Loopback, OK.
The program I was trying to download was written for the Stamp-2.
This happened on My Workbench PC (win98) and my Laptop (XP Pro).
After thinking I had 2 bad -2p's from Parallax, I stumbled on the problem.
The first line of code sets the type of Stamp you are talking to.
You have to remember to set the type of stamp you are using in the Editor.
(Select the right color stamp from the Tool Bar.)
Good Luck and hope this is your problem.
Alan Bradford
Plasma Technologies
I assume your stamp is OK. Someone else mentionned the ATN (pin 3)
already. This pin is needed to reset the stamp and to initiate
the programming sequence. It is merely a connection to RST: a high
on ATN pulls RST low. This raises two conditions that have to be
asserted:
1. ATN must be connected to serial DTR
2. ATN requires a high pulse and must no be held in high state.
while 2. is usually (not always) asserted by the software it is
a good idea to use a capacitor between ATN and DTR:
100n
DTR
ATN
_|_100n
GND
This cicuit also improves resistance to unwanted resets caused by
line noise. (If you read my some of my other posts here, you find
that I am stressing this point [noparse];)[/noparse]
Regards
Adrian
