Symbolic names for pins?
I'm trying to work out how to bind symbolic names to input pins. In
other words, I'd like to be able to refer to input pins using my own
name rather than IN1, IN2 etc.
Ideas?
_murat
Ideas?
_murat
Myled var out9
Switch var in2
Etc.
Of course, this doesn't work with things like HIGH and LOW that want
numbers. So don't say:
HIGH MyLed
Since that will set 0 or 1 HIGH, not pin 9. However, you can do this:
Myled var out9
Myledp con 9
HIGH Myledp
Al Williams
AWC
* NEW: PAK-VIa - Read PS/2 keyboards or mice -- double the buffer, lower
current consumption.
http://www.al-williams.com/awce/pak6.htm
> From: m [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MAZVPlIOyWRJFjGp--NhIuwH9r5WcV5NnAW-9mcblqhuwOUnXJP5urS4D2uobTrCP6f1k8ER_3zVmun2IhmWu6s]murat_stamp@e...[/url
> Sent: Tuesday, March 25, 2003 12:16 PM
> Subject: [noparse][[/noparse]basicstamps] Symbolic names for pins?
> Ideas?
> _murat
> from the same email address that you subscribed. Text in the
> If this is a BS2 or variant, try:
> Myled var out9
> Switch var in2
Yes, this did the trick. Cheers!
_murat
1. In PBASIC 2.0, you would alias them as variables, like this:
AlarmLevel VAR In1
This works because the Ins, Outs and Dirs registers (and their constituents)
are part of the variables pool.
2. In PBASIC 2.5 (you can download the beta compiler now), you can use the
new PIN defintion:
AlarmLevel PIN 1
The advantage to PIN is that some PBASIC functions require a numeric value
for the pin while others want the InX variable. Using the PIN declaration,
the compiler handles handles the details.
-- Jon Williams
-- Parallax
In a message dated 3/25/2003 12:16:39 PM Central Standard Time,
murat_stamp@e... writes:
> Ideas?
> _murat
issue that my buddy Al raises below.
-- Jon Williams
-- Parallax
In a message dated 3/25/2003 1:50:38 PM Central Standard Time,
alw@a... writes:
> Myled var out9
> Switch var in2
> Etc.
> HIGH MyLed
> Myled var out9
> Myledp con 9
> HIGH Myledp
> Al Williams
