Which coprocessor is best — Parallax Forums
edited 2003-03-26 02:32 in General Discussion
OK, guys, now my robot wander in my house, i got a small problem, my
stamp program is very touchy as far as timing, i cant add any
function, they servos motor dont run smooth anymore, so i figure i
need a coprocessor, i'm i right?. If so which one do you recommand,
and why, i'm the new guy on the block as far as stamp programming,
but got over 20 years of experience in robot AI.
so i'm anxous to read your feedback
thanks
John
ps: is anybody interrested in pictures of JORO2 i can download some
on this site
    edited 2003-03-25 07:35
    The one that Scott Edwards sells, the Mini SSC II works well. I have one,
    extremely easy to interface to the stamp, you can control up to 8 servos
    with on board or daisy chain a couple of the boards together for more
    servos. Have a look at http://www.seetron.com/ssc.htm for more information.
    It's not the cheapest controller on the block but it does it's job well from
    what I've seen.
    Chris Shuster
    Sent: Tuesday, March 25, 2003 11:36 AM
    Subject: [noparse][[/noparse]basicstamps] Which coprocessor is best
    > thanks
    > John
    > on this site
    edited 2003-03-25 14:24
    The PAK-VIII can do several things, including driving servos. If you
    don't need all 8 channels you can use others for other pulse output jobs
    including high-resolution PWM. http://www.al-williams.com/pak8.htm
    Al Williams
    AWC
    * Floating point math for the Stamp, PIC, SX, or any microcontroller
    http://www.al-williams.com/awce/pak1.htm
    > From: johneck26 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GwK8bb-bVabdzMK3qMykigv14evVqysy5YhG2EiFNszfdjC2BxpcEANCYnoTVWe2zRTpVjFsjfS71EsLcc4]johneck790@s...[/url
    > Sent: Monday, March 24, 2003 9:36 PM
    > thanks
    > John
    > on this site
    I'm using the PAK VIII on my BOE-BOT and it has made a world of
    difference in what my BOT can do now. I've only been working on it
    off and on for about a month or two now but it is able to wander all
    over the house and rarely gets in trouble. The PAK VIII is amazingly
    easy to use, especially with the software that you can download from
    the AWC site. With the PAK VIII I can really fine tune the obstacle
    avoidance system since it leaves so much processing time available.
    I am very interested to hear your specs on "JORO2".
    Hal
    --- In basicstamps@yahoogroups.com, "johneck26" <johneck790@s...>
    my
    > thanks
    > John
    > on this site
