Thanks to Chris and Ken, for my piezo
Wright on Chris, it was a piezo buzzer, i found a piezo speaker an
everything works fine, thanks alot i appreciate the help, in my days
we didnt have any piezo, so i'm kind new to this also, but now my
robot JORO2 his happy and chirping away...hihi.. also thanks to Ken
for his patience
John
--- In basicstamps@yahoogroups.com, Chris Savage
<knight_designs@y...> wrote:
> Sounds to me more like the device is a Piezo buzzer,
> which has it's own circuitry inside, if running it
> directly off 5V gives a tone. If that's the case,
> pulsing it with the stamp may not work.
> --- smartdim@a... wrote:
> > In a message dated 3/24/2003 10:59:23 AM Pacific
> > Standard Time,
> > johneck790@s... writes:
> > > Hi Ken,
> > > i'm connecting the piezo across +4.8v (4x1.2v
> > nimh) and ground
> > > and the current is 5 ma
> > > thanks
> > hmmmmmmmmm,
> > If indeed the unit is pulling only 5ma, the stamp
> > should be able to directly
> > drive the buzzer.
> > And, the NPN transistor idea should do the same. If
> > I remember correctly,
> > you stated you could pulse an LED?
> > When you pulsed the LED, was the stamp providing
> > ground for the buzzer, or
> > power.
> > If you pulsed the LED using ground, you should be
> > able to do the same to the
> > buzzer. And IF YOU ARE SURE the buzzer uses only
> > 5ma, no resistor is needed.
> > But to be safe, I recommend the transistor
> > idea....Again
> > 2n2222 or 2n3904
> > emitter to ground, base to the stamp pin through 1k
> > ohms and the collector to
> > one side of your buzzer and the other side of the
> > buzzer to your + 4.8 volts.
> > Is the 4.8 volt source using the same ground as the
> > stamp power supply? The
> > ground for your buzzer must be tied to the same
> > ground as your stamp.
> > Don't hesistate to write back if more help is
> > needed.
> > Ken
> > [noparse][[/noparse]Non-text portions of this message have been
> > removed]
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed.
> > Text in the Subject and Body of the message will be
> > ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
> Chris Savage
> Knight Designs
> 324 West Main Street
> Montour Falls, NY 14865
> (607) 535-6777
> http://www.knightdesigns.com
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your
desktop!
> http://platinum.yahoo.com
for his patience
John
> > Standard Time,
> > > Hi Ken,
> > nimh) and ground
> > > thanks
> > hmmmmmmmmm,
> > drive the buzzer.
> > power.
> > idea....Again
> > 2n2222 or 2n3904
> > needed.
> > Ken
> > removed]
> > ignored.
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
desktop!
"piezo speaker". If you normally tie one leg of the piezo to
ground, and the other to an I/O pin. If you use a simple
inverter (74C14) and connect the piezo across the input and
output of the inverter you effectively double the voltage that
the piezo sees to 10V from only a 5V source!
I/O>
o----| \o----> to piezo
o
> to piezo
-Beau Schwabe
>for his patience
>John
> > > Standard Time,
> > > > Hi Ken,
> > > nimh) and ground
> > > > thanks
> > > hmmmmmmmmm,
> > > drive the buzzer.
> > > power.
> > > idea....Again
> > > 2n2222 or 2n3904
> > > needed.
> > > Ken
> piezo speaker an
> help, in my days
> also, but now my
> also thanks to Ken
> for his patience
> John
No problem...In the past in pilfering Piezos from old
boards, it can be hard to tell if certain devices are
buzzers, or speakers (Piezo) when cased in the same
black housing, which I have both kinds here.
To differentiate, I simply apply 5-10VDC (Momentarily)
to one in the correct polarity (Both devices seem
polarized) and if it beeps, it's a buzzer...If not, I
assume it's the piezo speaker. That's my old logic
anyway...I rarely use the devices anymore except the
ones that come in computer cases in place of the
speaker. Anyway, take care!
Knight Designs
(607) 535-6777
Do you Yahoo!?
Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
Am I missing something? If you are using a 5V rail-to-rail supply, then
connecting it from either rail to an output pin should result in the applied
voltage being rail- to rail-, with the minuses being the amount of voltage
dropped internally when the pin is switched, or floated (on the other leg)
due to loading. So if you use an inverter, doesn't that still just give you
rail- to rail-, with pretty much the same rail to rail (minus those losses
above) applied voltage?
Mic
Sent: Tuesday, March 25, 2003 10:09 AM
Subject: Re: [noparse][[/noparse]basicstamps] Thanks to Chris and Ken, for my piezo
> Something I might point out if you need more volume from your
> I/O>
> o
> to piezo
> -Beau Schwabe
> >for his patience
> >John
> > > > Standard Time,
> > > > > Hi Ken,
> > > > nimh) and ground
> > > > > thanks
> > > > hmmmmmmmmm,
> > > > drive the buzzer.
> > > > power.
> > > > idea....Again
> > > > 2n2222 or 2n3904
> > > > needed.
> > > > Ken
michael_duerksen@c... writes:
> Beau:
> applied
> Mic
Mic & Beau,
I was wondering the same......
>In a message dated 3/25/2003 6:11:57 PM Pacific Standard Time,
> > Beau:
> > applied
> > Mic
>Mic & Beau,
Consider a piezo like a capacitor... charge it by applying power...
+5V>
|peizo|
<GND
+ 5V -
...Now reverse polarity...
GND>
|peizo|
<+5V
+ 5V -
...for a brief moment the piezo will
see 10V before it reverses polarity itself.
-Beau Schwabe
So, essentially, because of the switching process, which I didn't fully
understand then or now, so I'll take your word for that part, you will get a
LOUD but relatively short pulsed tone?
Sent: Wednesday, March 26, 2003 11:10 AM
> > > Beau:
then
> > > applied
voltage
leg)
give you
losses
> > > Mic
> >Mic & Beau,
> +5V>
|peizo|
<GND
> + 5V -
> GND>
|peizo|
<+5V
> + 5V -
> -Beau Schwabe
switching speed.
Folks, a piezo is a crystal, but it has properties similar to a capacitor.
Try this:
+9VBattery terminal>
piezo
momentary switch----<-9VBattery terminal
Initially when you press the button, the piezo will produce a louder pop, than
successive attempts at pressing the button, because the crystal in the piezo is
"charged" and deflects. Now, if you short the leads of the piezo without
applying
any power, you will hear another loud pop because now the crystal has become
"discharged" and relaxed. This mechanical motion results in the production of
sound.
Equiv circuit:
(charge)
piezo
(discharge)
-9VBattery terminal>
piezo
...with one terminal tied to ground the above circuit is essentially what
you are
doing when you toggle a pin HIGH or LOW.
Now think about this, instead of shorting the leads of the piezo as mentioned
above, simply reverse the polarity. This causes the piezo to "charge" in the
opposite direction thus causing the crystal to deflect in the opposite
direction.
With roughly twice the mechanical displacement, the result is a louder sound.
Equiv circuit: (notice no discharge!)
(charge)
piezo
(charge)
piezo
<+9VBattery terminal
-Beau Schwabe
>Thanks. Interesting thought. I never even heard of a piezo used that way.
>Mike
>From: Beau Schwabe <bschwabe@a...>
> > > > Beau:
>then
> > > > applied
>voltage
>leg)
>give you
>losses
> > > > Mic
> > >Mic & Beau,
> > +5V>
|peizo|
<GND
> > + 5V -
> > GND>
|peizo|
<+5V
> > + 5V -
> > -Beau Schwabe
