Can''t Communicate. Help.
Hi
You say you connected DTR straight to ATN, right? I do not
recommend this as it causes you trouble if DTR is held in the
wrong state (and holding the stamp in reset state). Use a capacitor
between DTR and ATN, e.g.:
100nF
DTR
ATN
_|_100nF
GND
Check the level on your stamp's ATN pin, if it is high this means that
the stamp is hold in reset state. The forementinned circuit avoids
this situation - and improves noise resistance besides that.
One thing more: 12V nominal (17V effective) to Vin is quite a lot,
I suggest to reduce it to something between 7V and 9V effective to
lower the stress on the stamp's internal regulator.
Regards
Adrian
100nF
DTR
ATN
_|_100nF
GND
Regards
Adrian
