how to connect a piezo to bs2 — Parallax Forums
edited 2003-03-24 21:57 in General Discussion
i know it's a basic question!
how do i connect a piezo speaker to an output of the stamp,
i try with a 470 ohm, but dont have the full volume as if i
connected to straight 5v.
thanks
John
    edited 2003-03-24 02:36
    In a message dated 3/23/2003 6:27:01 PM Pacific Standard Time,
    johneck790@s... writes:
    > thanks
    > John
    Assuming the peizo you are using is simply supplied with 5 volts you can do
    the following;
    Get a simple NPN transistor such as a 2n2222. Connect the emitter to ground.
    Connect the collector to one side of the peizo and the other end of the peizo
    to +5 volts (or +12)
    Connect a 1k ohm resistor between the base of the transistor and the output
    pin of the stamp.
    When you command the stamp pin to go high the peizo should sound and visa
    versa.
    Ken
    edited 2003-03-24 12:26
    > > thanks
    > > John
    you can do
    > the following;
    to ground.
    of the peizo
    the output
    > pin of the stamp.
    and visa
    > versa.
    > Ken
    Thanks Ken,
    try your circuit, dont work with my piezo, but i substitute a led
    with a resistor, and with command freqout the led flash, any idea,
    the piezo works fine on 5v
    John
    edited 2003-03-24 14:52
    In a message dated 3/24/2003 4:27:11 AM Pacific Standard Time,
    > Thanks Ken,
    > John
    When your piezo does work, are you suppling a pulsed signal, or simply 5v and
    ground?
    Ken
    edited 2003-03-24 14:55
    In a message dated 3/24/2003 6:54:21 AM Pacific Standard Time,
    smartdim@a... writes:
    > >Thanks Ken,
    > >John
    > and
    > ground?
    > Ken
    Also, do you know how much current your device consumes?
    edited 2003-03-24 18:56
    Hi Ken,
    i'm connecting the piezo across +4.8v (4x1.2v nimh) and ground
    and the current is 5 ma
    thanks
    John
    > > >Thanks Ken,
    led
    idea,
    > > >John
    simply 5v
    > > and
    > > ground?
    > > Ken
    edited 2003-03-24 19:36
    In a message dated 3/24/2003 10:59:23 AM Pacific Standard Time,
    > Hi Ken,
    > thanks
    hmmmmmmmmm,
    If indeed the unit is pulling only 5ma, the stamp should be able to directly
    drive the buzzer.
    And, the NPN transistor idea should do the same. If I remember correctly,
    you stated you could pulse an LED?
    When you pulsed the LED, was the stamp providing ground for the buzzer, or
    power.
    If you pulsed the LED using ground, you should be able to do the same to the
    buzzer. And IF YOU ARE SURE the buzzer uses only 5ma, no resistor is needed.
    But to be safe, I recommend the transistor idea....Again
    2n2222 or 2n3904
    emitter to ground, base to the stamp pin through 1k ohms and the collector to
    one side of your buzzer and the other side of the buzzer to your + 4.8 volts.
    Is the 4.8 volt source using the same ground as the stamp power supply? The
    ground for your buzzer must be tied to the same ground as your stamp.
    Don't hesistate to write back if more help is needed.
    Ken
    Sounds to me more like the device is a Piezo buzzer,
    which has it's own circuitry inside, if running it
    directly off 5V gives a tone. If that's the case,
    pulsing it with the stamp may not work.
    > Standard Time,
    > > Hi Ken,
    > nimh) and ground
    > > thanks
    > hmmmmmmmmm,
    > drive the buzzer.
    > power.
    > idea....Again
    > 2n2222 or 2n3904
    > needed.
    > Ken
    > removed]
    > from the same email address that you subscribed.
    > Text in the Subject and Body of the message will be
    > ignored.
    Knight Designs
    324 West Main Street
    Montour Falls, NY 14865
    (607) 535-6777
    http://www.knightdesigns.com
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
    http://platinum.yahoo.com
