ac adapter — Parallax Forums
ac adapter
edited 2003-03-24 03:20 in General Discussion
hi, I've been using a 9v battery to power my basic stamp but now I
found an old ac adapter in my basement which outputs 9v DC at 300mA,
would that be ok for the basic stamp 2sx?
    edited 2003-03-23 00:32
    In a message dated 03/22/2003 19:31:27 Eastern Standard Time,
    hard-on@t... writes:
    Pretty marginal. You should have at least 500ma.
    Sid
    edited 2003-03-23 00:37
    I
    300mA,
    > Sid
    this website mentions only 60mA needed under 'current requirements':
    http://www.warburtech.com/Basic%20Stamps/BS2SX-IC/BS2SX-IC.htm
    I was just worried that 300mA would be too much....
    edited 2003-03-23 00:43
    In a message dated 03/22/2003 19:38:26 Eastern Standard Time,
    You could have 3000ma and it would matter. The Stamp only takes what it
    needs. The 300ma only indicates the capacity of the adapter.
    Sid
    edited 2003-03-23 00:46
    In a message dated 03/22/2003 19:44:00 Eastern Standard Time, Newzed@a...
    writes:
    Type. Should have said " it wouldn't matter". Sorry
    Sid
    edited 2003-03-23 00:50
    Newzed@a...
    > writes:
    what it
    > Sid
    the fact that the mA written on the adapter represents a capacity and
    not an actual output makes plenty of sense...Duh. Thanks a lot, saved
    me from making another expensive radio shack purchase, I'm running
    out of money.
    edited 2003-03-23 00:58
    In a message dated 3/22/2003 4:31:28 PM Pacific Standard Time,
    Yes if it is a somewhat clean source. It won't hurt anything to plug it in
    and try it. If it will not run on your 9v AC adaptor, verify that the input
    to the stamp is above 7 volts. If the input is above 7 volts and it will not
    run your stamp, but a 9v battery will run the stamp, I suspect the DC source
    from your AC adapter is "dirty."
    Ken
    Only the voltage matters when it comes to "oversized" adapters. If you apply
    5 volts to the stamp it'll take the same amount of juice whether your
    adapter capacity is 300 milliamp or 300 amp. Remember, current is determined
    by voltage and resistance (V=I/R). Since the resistance of your stamp is
    fixed, only raising the voltage can (and will) really hurt it.
    My 'lectronic Newb site http://members.shaw.ca/pmeloy/
    Sent: Saturday, March 22, 2003 4:37 PM
    Subject: [noparse][[/noparse]basicstamps] Re: ac adapter
    > I
    > 300mA,
    > > Sid
    edited 2003-03-23 00:59
    In a message dated 3/22/2003 4:38:20 PM Pacific Standard Time,
    > I
    > 300mA,
    > >Sid
    No, 300 ma is not "too much" the stamp will take what it needs. If the stamp
    and periphial equipement will pull more current that your adapter can handle,
    the voltage from the adapter will decrease.
    Plug it in and try it. You will not hurt anything.
    edited 2003-03-23 01:00
    In a message dated 3/22/2003 4:43:35 PM Pacific Standard Time, Newzed@a...
    writes:
    > Sid
    Sid is CORRECT!
    edited 2003-03-23 18:15
    the device will only draw what it needs but be careful
    not all adapters are the same the output level seems
    to follow the current rating i have found some rated
    6v 1700 mha with voltage levels unloaded as high as
    21volts in a power surge that could triple over rating
    a 5 volt regulator to destruction so remember the
    rating on the adaptor is for whatever voltage while
    it is under a current load unloaded can be much higher
    > Standard Time,
    > much....
    > adapter.
    > Sid
    > removed]
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
    http://platinum.yahoo.com
    Sure, I do this all the time - but some adapters are only
    rectified and don't have any builtin capacitance to smooth out
    the supply voltage. It's best to put the output on a scope
    before commiting to one particular adapter. For those you'll
    have to add your own filter caps as appropriate for your current
    requirements.
    History says King George is gone,
    But I just saw him on the White House lawn!
    He has no bounds, and accepts no borders,
    If Congress won't do it, he "Executive Orders".
