positive ramp detection
Hallo,
I have already a load cell based weigh scale using BS2 and I want to build a
checkweigher.
In this application a package entering the weigh station conveyor,so how can
a positive entry ramp signals be detected so that as the ramp signal levels
is off,the package is fully on the weigh station conveyor and then the
weight can be determined.Any help would be appreciated.
Thank You
Mohamed Refky
_________________________________________________________________
MSN 8 with e-mail virus protection service: 2 months FREE*
http://join.msn.com/?page=features/virus
checkweigher.
Thank You
Mohamed Refky
How about two IR sensors at the far edges of the weigh station. After the
first beam is broken, the conveyer continues until it is no longer broken.
If it breaks the second beam and the first is intact, then it needs to back
up. If both beams are broken, the package is too large and can set off a
warning device.
Jonathan
www.madlabs.info
Sent: Saturday, March 22, 2003 11:28 AM
Subject: [noparse][[/noparse]basicstamps] positive ramp detection
> Hallo,
a
> checkweigher.
can
levels
> Thank You
> Mohamed Refky
the signal to load starts the part onto the scale until the first
remote beam is broken, then stops. if the two inner beams are
broken, fine, if either of the two outter beams are broken, then the
part is too long or not centered, either way, a fault.
Dave
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Mohamed,
After the
broken.
to back
off a
> warning device.
> Jonathan
> www.madlabs.info
> From: "Mohamed REFKY" <refky@h...>
> > Hallo,
to build
> a
> > checkweigher.
conveyor,so how
> can
signal
> levels
then the
> > Thank You
> > Mohamed Refky
Subject and
I did not want to do this with external devices,I want to write a code that
detects the increasing in the weight readings which already the BS2 gets
from the load cell A/D and check when the weight stops increasing.
Date: Sat Mar 22, 2003 7:36 pm
Subject: Re: [noparse][[/noparse]basicstamps] positive ramp detection
Mohamed,
warning device.
Jonathan
www.madlabs.info
>Reply-To: basicstamps@yahoogroups.com
>Date: Sat, 22 Mar 2003 21:28:12 +0200
>Hallo,
>a
>checkweigher.
>can
>Thank You
>Mohamed Refky
Help STOP SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=features/junkmail
