Out of VAR memory?
Hi all,
I have a program with a total of 16 cons and vars. Most vars are bytes. Yet
I am being told I am out of memory room. I can't seem to find that maximum
allowable number of vars in my manual, but I have other programs with more,
I am sure. What gives?
Jonathan
www.madlabs.info
Jonathan
www.madlabs.info
Make sure you're only declaring the actual size you need: use Bits and
Nibbles when the values they'll hold will allow. Also, reuse variables when
possible; often variables are localized to a routine and their value does not
need to be maintained through the run of the program. In this case, you can
use aliasing to rename a variable to keep your program readable, but will
save you space.
-- Jon Williams
-- Parallax
In a message dated 3/22/2003 12:26:52 PM Central Standard Time,
jpeakall@m... writes:
> Hi all,
> Thanks,
> Jonathan
> www.madlabs.info
I was nowhere near 26 bytes. Good to know what the ceiling is. Oddly, I
tried cutting and pasting the code into new document, and the problem went
away. Same code, same Stamp designation, word for word. I have occasionally
run into this kind of "tainted file" before, but not with the Stamp editor.
Jonathan
Sent: Saturday, March 22, 2003 10:34 AM
Subject: Re: [noparse][[/noparse]basicstamps] Out of VAR memory?
> The BASIC Stamp has 26 bytes of user RAM in the VAR space; so somthing is
up.
when
not
can
> save you space.
> -- Jon Williams
> -- Parallax
> > Hi all,
Yet
maximum
more,
> > Thanks,
> > Jonathan
> > www.madlabs.info
> Jon,
> Jonathan
Jonathan,
I too have had code that "HAD TO WORK" but did not. I too remember cutting
the entire listing and pasting into a new document and the problem went away.
Ken
