help on stepper programming
I need some help on programming a stepper to turn accordingly based
on port6. If in6(port6) equals 1, the unipolar, 4-phase, 6-lead,
stepper turns 90 degrees(17 degrees/step) clockwise; after in6 goes
back to 0, the stepper returns to starting position.
The stepper stiffens as soon as powered up, and I can feel the
resistance. But it just sits there regardless the status of in6, so
if anyone knows the problem please kindly point it out. Am I pulsing
the ULN2003 incorrectly?
'Using ports 7-10 to pulse the stepper motor, and a ULN2003 is used*
'to drive the 17 degree/step stepper motor**************************
output 7
output 8
output 9
output 10
'I/O definition *
coils VAR outB 'output to stepper coils
'EEPROM DATA *
step1 DATA %1100
step2 DATA %0110
step3 DATA %0011
step4 DATA %1001
step5 DATA %1100
'*Initilization *
DirB = %1111 'make stepper pins outputs
gate:
Read step1, coils
pause 100
Read step2, coils
pause 100
Read step3, coils
pause 100
Read step4, coils
pause 100
Read step5, coils
pause 100
NEXT:
puase 20
If in6=1 Then NEXT
If in6=0 Then CLOSE
CLOSE: 'than if pin6 is low(no car anymore), gate
closes
Read step4, coils
pause 100
Read step3, coils
pause 100
Read step2, coils
pause 100
Read step1, coils
pause 100
goto detect
Any help is greatly appreciated.
Mick
output 7
output 8
output 9
output 10
'I/O definition *
'EEPROM DATA *
step1 DATA %1100
step2 DATA %0110
step3 DATA %0011
step4 DATA %1001
step5 DATA %1100
'*Initilization *
gate:
Read step1, coils
pause 100
Read step2, coils
pause 100
Read step3, coils
pause 100
Read step4, coils
pause 100
Read step5, coils
pause 100
NEXT:
puase 20
If in6=1 Then NEXT
If in6=0 Then CLOSE
closes
Read step4, coils
pause 100
Read step3, coils
pause 100
Read step2, coils
pause 100
Read step1, coils
pause 100
goto detect
Mick
prevent compiling. If this is a complete listing you are missing the
stamp declaration, using Reserved words for labels, using undefined
labels, and using OUTB incorrectly.
NEXT is a reserved word - use something else.
your last statement GOTO DETECT - detect is not defined, did you mean
where NEXT is?
Apparantly you have wired your stepper to pins 7,8,9,10. From then
on you refer to OUTB which is Pins 4,5,6,7.
If you are using the current Stamp editor you need to start your
listing with '{$STAMP BS2} (if you are using BS2).
I'm just wondering how you got this listing loaded into your Stamp
since as it stands it won't compile. Also, be prepared to alter the
sequence of wiring to your stepper several times to get it to rotate
and not just flip back and forth.
Good luck
--- In basicstamps@yahoogroups.com, "nobodywantstobeasucker"
<nobodywantstobeasucker@y...> wrote:
> Hi,
based
so
pulsing
> output 7
> output 8
> output 9
> output 10
> 'I/O definition
> 'EEPROM DATA
> step1 DATA %1100
> step2 DATA %0110
> step3 DATA %0011
> step4 DATA %1001
> step5 DATA %1100
> '*Initilization
> gate:
> Read step1, coils
> pause 100
> Read step2, coils
> pause 100
> Read step3, coils
> pause 100
> Read step4, coils
> pause 100
> Read step5, coils
> pause 100
> NEXT:
> puase 20
> If in6=1 Then NEXT
> If in6=0 Then CLOSE
gate
> closes
> Read step4, coils
> pause 100
> Read step3, coils
> pause 100
> Read step2, coils
> pause 100
> Read step1, coils
> pause 100
> goto detect
> Mick
