BS2 and Plant Perception (Backster Effect) — Parallax Forums
edited 2003-03-25 20:15 in General Discussion
I read almost every post that comes through, and I appreciate all the
great information that everyone shares on this forum. That is the
reason I am working with the BASIC Stamp and not another
microcontroller.
My question is really off-the-wall, but has some utility in it (at
least to me): has anyone interfaced a BS2 and associated circuitry to
a living plant? For instance, I would be interested in learning how
someone (Dr. Tracy Allen?) may recommend connecting various
electronic circuitry to a plant (say, shrub or potted plant) to
monitor various physical parameters including water uptake,
transpiration, etc. I know EME Systems offers leaf wetness sensors,
and this may be a place to start.
The off-the-wall part is: any ideas on how to proceed with connecting
a polygraph to said plant for monitoring purposes? Any plant
physiologists out there with interfacing ideas?
Thanks for any comments.
-George Sutton
    edited 2003-03-20 23:09
    Just a thought...if you wanted to you could use various mostiure
    sensors integrated into the plant itself or on the plant. I spaced
    correctly and with enough of them you could monitor different parts
    of the plant to account for any "spot effects". I you used sensors
    that restrict the voltage dependent on moisture present or something
    like that those readings could be integrated as variables. Those
    variables could then be put into if...then statements that could
    respond in the desired fashion. Once again it's just a
    thought...feel free to tell me if I'm full of balogna.
    Chris P.
    edited 2003-03-21 03:27
    Hi George,
    I setup and operate TDR systems for measuring volumetric water content for
    my employer. It is very expensive, but incredibly accurate. Try this site
    to get you started, and look under the tdr link.
    http://www.sowacs.com
    Hope this helps,
    -Steve
    >microcontroller.
    >-George Sutton
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-03-22 00:15
    Steve and Chris P.:
    Thanks for the information. Chris, your ideas are not anymore
    bologna than mine are! I appreciate the response. I will
    incorporate some of your ideas into my plan...
    Steve, I am a little familiar with TDR, especially as it is applied
    to mudslides and landslide monitoring. I know William Kane and am
    familiar with his work. BTW, your firm's website is very
    informative, and I will look it over. Any personal ideas about using
    a BS2 with TDR, and is it even possible??
    Thanks for the replies, both of you.
    --- In basicstamps@yahoogroups.com, sargent@s... wrote:
    > Hi George,
    content for
    this site
    > Hope this helps,
    > -Steve
    the
    > >microcontroller.
    to
    how
    sensors,
    connecting
    > >-George Sutton
    Subject and
    edited 2003-03-22 05:48
    Hi George,
    I'm not affiliated with the Sowacs web site. Sowacs is one of the more
    informative site's for sensors related to agriculture. I'd bet Tracy Allen
    will respond when he gets a chance, he's a pro at this stuff. There are a
    couple of relatively low cost TDR sensors designed for measuring water
    content. One that I'm familiar with and is pretty easy to interface to a
    Stamp is the CS615 from Campbell Scientific. Unfortunately this model is
    being phased out, and replaced with the CS616 model, which could be
    interfaced to a Stamp but will take a little more work. These sensors run
    about $200 each.
    http://www.campbellsci.com/soilvol.html
    A cheaper approach would be a Watermark sensor, which Tracy Allan has
    generously supplied some great info on is located here
    http://www.emesystems.com/OL2mhos.htm
    Hope this helps,
    Steve
    edited 2003-03-24 23:43
    > Hi George,
    content for
    this site
    > Hope this helps,
    > -Steve
    the
    > >microcontroller.
    to
    how
    sensors,
    connecting
    > >-George Sutton
    Subject and
    Steve,
    On further thought, I doubt the BS2 would have the speed to interface
    to and generate a TDR signal. What do you think? From what little I
    know, TDR requires something on the order of a 200uSec sending and
    even less detection time.
    Mekkatronix
    edited 2003-03-25 00:01
    George,
    Yes, your right about the speed. I'm sorry I wasn't very clear, I have a
    bad habit of sending half worked out thoughts.
    The CS615 and CS616 are TDR water content probes, with the high speed
    circuitry built into the probe. The downside is the accuracy of these self
    contained probes. Typically +/- 3 % VWC.
    The upside is low cost, no maintenance required (bury it and forget it) and
    the probe has an output that can be interfaced to the Stamp fairly easily.
    Both probes output a varying frequency in relation to water content.
    The CS615 output is a +/- 2.5 vdc square wave in the range of 700 Hz to
    1500 Hz.
    The CS616 output is +/- 0.7 vdc and the period ranges from 16 to 32
    microseconds, quite a bit faster. This probe would require a comparator or
    something similar to shift the 0.7 vdc to something the Stamp pin would
    recognize, with 1.5 vdc usually being the minimum.
    If you then run the probe input into the stamp pin via say a 22 K ohm
    resistor, this will allow the Stamps internal protection diodes to safely
    remove the negative side of the signal and then finally use the count command.
    Hope this doesn't muddy the water anymore,
    Steve
    >Steve,
    >Mekkatronix
    Steve,
    Thanks for the reply. I appreciate your comments. If you have
    additional information or ideas that could help me interface BS2 to
    TDR applications, please feel free to contact me off-list at
    mekkatronix@y....
    Sincerely,
    George
    > George,
    have a
    speed
    these self
    it) and
    easily.
    Hz to
    > 1500 Hz.
    comparator or
    would
    ohm
    safely
    count command.
    > Steve
    > >Steve,
    interface
    little I
    > >Mekkatronix
    Steve,
    mekkatronix@y....
    Sincerely,
    George
    > George,
    have a
    speed
    these self
    it) and
    easily.
    Hz to
    > 1500 Hz.
    comparator or
    would
    ohm
    safely
    count command.
    > Steve
    > >Steve,
    interface
    little I
    > >Mekkatronix
    Steve,
    mekkatronix@y....
    Sincerely,
    George
    > George,
    have a
    speed
    these self
    it) and
    easily.
    Hz to
    > 1500 Hz.
    comparator or
    would
    ohm
    safely
    count command.
    > Steve
    > >Steve,
    interface
    little I
    > >Mekkatronix
