motorola mc14543 versus CD 4543 in3 digit counter
Archiver
i am having a problem constructing a 3 digit counter. The original
circuit was based in 2 main integrated circuit: MC14553 and
MC14543.As i could not find the motorola mc14543 integrated circuit
i used a 4543 which apparently should do the same job as is
identical in pin configuration and function as a 7 segments BCD
decoder.
i would appreciate any help or confirm whether the two IC are
perfect for substitution.
decoder.
http://www.virtualbreadboard.com/READ/vbb/Help/Packages/CMOS4000/4543.htm#Datash
eet
The unit is a BCD to Seven segment decoder..
If your unit doesn't respond maybe your program or wires need checked?
Please attached file(s) and below web link for the position advertised.
Leroy Hall
Sent: Wednesday, March 19, 2003 6:57 AM
Subject: [noparse][[/noparse]basicstamps] motorola mc14543 versus CD 4543 in3 digit counter
: i am having a problem constructing a 3 digit counter. The original
: circuit was based in 2 main integrated circuit: MC14553 and
: MC14543.As i could not find the motorola mc14543 integrated circuit
: i used a 4543 which apparently should do the same job as is
: identical in pin configuration and function as a 7 segments BCD
: decoder.
: i would appreciate any help or confirm whether the two IC are
: perfect for substitution.
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the Subject and Body
: Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
problems!
: problems!
: [noparse][[/noparse]Non-text portions of this message have been removed]
Leroy Hall
http://home.fuse.net/leroy
513 697-8583 work
513 697-7539 home
513 697-8281 FAX
Sent: Wednesday, March 19, 2003 10:37 AM
Subject: Re: [noparse][[/noparse]basicstamps] motorola mc14543 versus CD 4543 in3 digit counter
: I looked at a pinout of a 4543 at:
: eet
: The unit is a BCD to Seven segment decoder..
: If your unit doesn't respond maybe your program or wires need checked?
: Please attached file(s) and below web link for the position advertised.
: Leroy Hall
: From: "jonabadtesta" <jonabadtesta@y...>
: To: <basicstamps@yahoogroups.com>
: Sent: Wednesday, March 19, 2003 6:57 AM
: Subject: [noparse][[/noparse]basicstamps] motorola mc14543 versus CD 4543 in3 digit counter
: : i am having a problem constructing a 3 digit counter. The original
: : circuit was based in 2 main integrated circuit: MC14553 and
: : MC14543.As i could not find the motorola mc14543 integrated circuit
: : i used a 4543 which apparently should do the same job as is
: : identical in pin configuration and function as a 7 segments BCD
: : decoder.
: : i would appreciate any help or confirm whether the two IC are
: : perfect for substitution.
: : To UNSUBSCRIBE, just send mail to:
: : basicstamps-unsubscribe@yahoogroups.com
: : from the same email address that you subscribed. Text in the Subject and
Body
: of the message will be ignored.
: : Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
