Select/Case
Hi Stampers,
I really like the new commands but I think I didN't quite understand the
SELECT CASE command and the TCASE option. If someone could look at the code
below (that works fine now) and tell me if I could change the several SELECT
CASE-routines into a single bigger one by using TCASE or something. I tried
but didnot succeed either with TCASE nor with CASE. What does the second
CASE-block of a routine do when the preceeding did / didn't apply?
Thanks for your help, Uli
CODE AS FOLLOWS:
Select sensorport
case 1,3,5,7,9,11,13,15
if K_index_A = 0 then
high Bremse_A
K_index_A = 1
endif
endselect
Select sensorport
case 2,3,6,7,10,11,14,15
if K_index_B = 0 then
high Bremse_B
K_index_B = 1
endif
endselect
Select sensorport
case 0,2,4,6,8,10,12,14
K_index_A = 0
low bremse_A
endselect
Select sensorport
case 0,1,4,5,8,9,12,13
K_index_B = 0
low bremse_B
endselect
Select sensorport
case 4,5,6,7,12,13,14,15
if R_index_A = 0 then
rundenzahl_A = rundenzahl_A+1
R_index_A = 1
endif
endselect
Select sensorport
case 8 to 15
if R_index_B = 0 then
rundenzahl_B = rundenzahl_B+1
R_index_B = 1
endif
endselect
Select sensorport
case 0,1,2,3,8,9,10,11
R_index_A = 0
endselect
Select sensorport
case 0 to 7
R_index_B = 0
endselect
'debug cls
'debug? sensorport,cr
'debug? K_index_A
'debug? K_index_B
'debug? R_index_A
'debug? R_index_B
'debug cr
goto start
CODE AS FOLLOWS:
Select sensorport
high Bremse_A
K_index_A = 1
endif
endselect
Select sensorport
high Bremse_B
K_index_B = 1
endif
endselect
Select sensorport
K_index_A = 0
low bremse_A
endselect
Select sensorport
K_index_B = 0
low bremse_B
endselect
Select sensorport
R_index_A = 1
endif
endselect
Select sensorport
case 8 to 15
R_index_B = 1
endif
endselect
Select sensorport
R_index_A = 0
endselect
Select sensorport
case 0 to 7
R_index_B = 0
endselect
'debug cls
'debug? K_index_A
'debug? K_index_B
'debug? R_index_A
'debug? R_index_B
'debug cr
goto start
possibly your program uses more selects than are neccessary, it
depends on what you intend to do. Wich each new select you are
re-reading sensorport (which may be what you intend/need to do).
I assume sensorport ranges from 0 to 15, so you could simplify some
of your cases to a more efficient if statement:
select sensorport
could be replaced by
if sensorport.bit0 = 1 'all odd values
and
select sensorport
if sensorport.bit0 = 0 'all even values
The difference between case and tcase is that after a case clause
execution continues after the endselect,
after a Tcase execution continues after the Tcase clause possibly
leading into a following case/tcase clause.
Example:
For x = 1 the following select executes actions_1 only, for x = 3
it executes actions_2.
select x
case 1
actions_1
case <5
actions_2
endselect
For x = 1 the following select executes actions_1 and actions2 as
x is = 1 and < 5 as well, for x = 3 it executes actions_2 only.
select x
tcase 1
actions_1
case <5
actions_2
endselect
regards
Adrian
