Remote control with RF transmitters/receiver — Parallax Forums
edited 2003-03-22 13:41 in General Discussion
I purchased the RF modules, model TXLC-434 / RXLC-434, from Reynolds
Electronics. Does anyone have some sample code they could share with me for
stamp to stamp serial connection?
    edited 2003-03-19 00:43
    Trkeenan,
    It is so simple you won't believe it. Bruce has some sample code at:
    http://www.rentron.com/Stamp_RF.htm
    Although this code is for the RWS/TWS 434, Bruce tells me it should work
    fine. They both use serial communications. I recently bought a pair but
    haven't used them yet. If you have any trouble, mail him and I'm sure he
    will help you out.
    Jonathan
    www.madlabs.info
    Sent: Tuesday, March 18, 2003 4:05 PM
    Subject: [noparse][[/noparse]basicstamps] Remote control with RF transmitters/receiver
    for
    edited 2003-03-19 01:16
    Here's an article for sending/receiving serial data via RF using one of the PIC
    compilers. Converting the code to PBASIC should be very easy. It includes
    CRC, Manchester encode/decode routines, and should definitely give you a
    good starting point.
    http://www.picbasic.org/filedb/pafiledb.php?action=download&id=18
    -Bruce
    tech@r...
    Sent: Tuesday, March 18, 2003 5:05 PM
    In a message dated 3/18/03 5:43:15 PM Mountain Standard Time,
    jpeakall@m... writes:
    > will help you out.
    Thanks every one for the help. I figured it out and I am very happy.
    Tim
