Strange serial problems - Maxim 3100
Thanks for the info folks, much appreciated!
I have taken a look at the Basic ATOM and i have one ordered, it looks like
the ideal solution to me. However i wouldn't mind having a go at using an
external UART with the BS2 and the Maxim 3100 looks perfect for the job, as
i need one with a TTL interface (the 3110 won't do). Any suggestions on
other UART's would be welcome, but the Max3100 seems rather unique.
Can anyone list a supplier for the Max 3110 in the UK - i can't seem to find
one anywhere?
Thanks again,
> From: brent5377 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9STt9LQB67JVJugvB5xrbULTya-Qm8o0Rzgjg7PajKkB9T1saxIjkI-D9MbzpcHmk0vZ1oa6wmhl7yQZbmLIPw]broyles@i...[/url
> Sent: 16 March 2003 12:04 AM
> Subject: [noparse][[/noparse]basicstamps] Re: Strange serial problems
> Mark,
> I am a few months in front of you with various serial problems. Two
> great sources of info have been
> www.phanderson.com/stamp/tutorial 10.html
> www.emesystems.com/BS2rs232.htm
> http://www.wd5gnr.com/suart.htm
> The second link has a lot of info concerning wait timing between
> tx of a command and when the stamp is ready to receive (rx).
> The third is a note about a serial buffer. I can only buffer about 8
> bits at a time which is too few for my application.
> The upshot is the stamp won't be able to receive a command after a tx
> command for over 1/2 a second!!
> One helpful command only available to the faster chips (I am using
> a 2p24 stamp) is the SPSER command. It is an unpublished command that
> takes a serin command and places the data in the scratch pad memory
> area.
> Email me offline and I can give you some of my code and an email from
> Jon Williams, who helped me greatly, if you would like.
> What I am ending up doing is strapping two stamps together to send a
> tx command from one chip and have the other stamp in rx mode waiting
> for the reply. It is a bit of a pain. I am just getting into it.
> One of the other tricks is keeping the baud rates down. I am stuck
> because my external devices are only 9600.
> If you need any ttl to rs232 level converters Al Williams one is
> fairly cheap, works well and goes directly into proto board.
> http://www.al-williams.com/rs1.htm
> I am using 4 of them.
> --- In basicstamps@yahoogroups.com, "Mark Lamond" <lists@m...> wrote:
> > Hi, thanks for the info Phillip
> > The problem is that i am stuck with the one baud rate, i can't
> change it [noparse]:([/noparse]
> > The only way i can think round it is to have a routine seperate
> from the
> > main program constantly monitoring for serial data on my input pin
> and if it
> > sees data it stores it in a variable. However i'm not aware of any
> way to do
> > this on the Stamp (i have a BS2SX).
> > Has anyone got any ideas (i am a bit of a Stamp newbie)?
> > > I have had similar problems and reducing the speed was the only
> solution I
> > > found! Try 2400 or 4800, It if it works try 9600. I have not been
> able to
> > > get about the 9600 mark reliably...
> > > Good Luck,
> > > Phillip Kocmoud
> > > From: Mark Lamond [noparse][[/noparse]mailto:lists@m...]
> > > Sent: Saturday, March 15, 2003 11:23 AM
> > > Subject: [noparse][[/noparse]basicstamps] Strange serial problems
> > > Hi there,
> > > I have a BS2 set up to send and recieve serial data from a
> > > microcontroller.
> > > The BS2 sends a single byte to the device, then listens for a
> single byte
> > > reply. For instance if i send $FF to the device it should return
> $FF. For
> > > the moment i am displaying the recived data via the debug output.
> > > Comms are
> > > running at 19200bps, and both devices are talking TTL levels with
> the
> > > Stamp's I/O lines directly connected to the serial port of the
> target
> > > device's microcontroller.
> > > Pin 0 is connected to the target's RX
> > > Pin 5 is connected to the target's TX
> > > Here is my code:
> > > Byte VAR BYTE
> > > Byte = 0
> > > DEBUG "Sending Data", CR
> > > SEROUT 0, 110, [noparse][[/noparse]$FF]
> > > SERIN 5, 110, [noparse][[/noparse]Byte]
> > > DEBUG "Recieved Data", CR
> > > DEBUG Byte, CR
> > > I am using a PC to sniff both serial lines between the target
> device and
> > > Stamp so i can see in real time what is happening. When the
> program is
> > > started running it sends $FF to the device as expected, and the
> device
> > > replies with $FF - however the stamp seems not to have noticed
> > > this and sits
> > > waiting for a serial input.
> > > If i use my PC to "inject" an $FF into the line connecting to Pin
> 5 while
> > > the Stamp is waiting for input, the stamp correctly recieves the
> byte,
> > > displays it via the debug output and the program stops.
> > > This makes me think that the Stamp isn't quick enough to catch
> the data on
> > > Pin 5 after it has processed the SEROUT command and misses the
> > > data from the
> > > target device? Can anyone throw any light on what i might be
> > > doing wrong, or
> > > how to get round the problem? Perhaps i need a faster Stamp?
> from the same email address that you subscribed. Text in the
one anywhere?
Thanks again,
> Mark,
> area.
> from the
> and if it
> way to do
> solution I
> able to
> > > Good Luck,
> > > Phillip Kocmoud
> > > Hi there,
> > > microcontroller.
> single byte
> $FF. For
> > > Comms are
> the
> target
> > > Here is my code:
> > > Byte VAR BYTE
> > > Byte = 0
> > > DEBUG Byte, CR
> device and
> program is
> device
> > > this and sits
> 5 while
> byte,
> the data on
> > > data from the
> > > doing wrong, or
Here is an rs232 32 byte buffer chip... RSB509B $7.95 US.
http://www.protean-logic.com/tickit/rsb509B_HTML_Cutsheet.htm
John
looks like
using an
job, as
suggestions on
seem to find
> one anywhere?
> Thanks again,
> > From: brent5377 [noparse][[/noparse]mailto:broyles@i...]
> > Mark,
Two
about 8
a tx
that
memory
> > area.
from
send a
waiting
> > from the
pin
> > and if it
any
> > way to do
only
> > solution I
been
> > able to
> > > > Good Luck,
> > > > Phillip Kocmoud
> > > > Hi there,
> > > > microcontroller.
> > single byte
return
> > $FF. For
output.
> > > > Comms are
with
> > the
> > target
> > > > Here is my code:
> > > > Byte VAR BYTE
> > > > Byte = 0
> > > > DEBUG Byte, CR
> > device and
> > program is
the
> > device
> > > > this and sits
Pin
> > 5 while
the
> > byte,
> > the data on
> > > > data from the
> > > > doing wrong, or
