Serial port recording ?
I have two DCF 77-clock-module (ELV.de) with serial connecter to the PC.
including the "time program"
I would like to connect it to the stamp, but can't get the protocol
how it communicate with the PC.
Is there a program who record the serial port of the PC ??
Then may be I can find out how I could connect the DCF 77-modul
to my Stamp?
Somebody knows a link or has an idea how I could start?
Thanks Heinz Germany
to my Stamp?
http://www.ericphelps.com/commlink/index.htm (I've used this one.
Be sure to download the excel spreadsheet to convert binary back to
hex.)
http://www.kmint21.com/serial-port-monitor/
John
--- In basicstamps@yahoogroups.com, "HSchwenk_GMX" <hschwenk@g...>
wrote:
> Hi,
the PC.
> to my Stamp?
Your links are interesting
Thanks Heinz
Sent: Tuesday, March 18, 2003 3:38 AM
Subject: [noparse][[/noparse]basicstamps] Re: Serial port recording ?
> Here are a few sites to look at....
> hex.)
> John
> wrote:
> > Hi,
> the PC.
> > to my Stamp?
wrote:
> Hi,
the PC.
protocol
> to my Stamp?
Hi
This may not be exactly applicable but check out the BASIC STAMP DAQ
(data acquisition) - it is on the download tab at parallax.com.
It is a VB macro within an excel spreadsheet, which reads input from
a serial port (e.g. stamp, other device), and records the input on
the spreadsheet.
I've made some tweaks to it so I can send signifcant ammounts of
information down to the device as well as receiving it, so if that
is a problem for you let me know and I can send you my 'tweak' code.
Depending on whether you are using shiftin/out or serin/out you may
end up with race condition problems (i.e. the serial device sends
information before the pc is ready for it and vice versa). If using
serin/out make sure you understand the use of the timeout function
really clearly. This cost me a week or so of confusion.
Hope that helps.
