[[basicstamps] Speaker Volume] — Parallax Forums
edited 2003-03-16 01:40 in General Discussion
I have an LM386 that I plan to use. Also I can dig up some simple transistor
amps from some documents I have around here somewhere. I have 3 SN76477 Texas
Instruments Complex Sound Generators from circa 1978 that I plan to play with
again, and I recall a simple transistor amp was in that data sheet. [noparse]:)[/noparse]
"Allan Lane" <allan.lane@h...> wrote:
> I have a question for the group.
> I'd like to have my Stamp produce tones --
> which I know how to do, thank you,
> but I want it to do it with programmable
> volume, so it can get LOUD if I want
> it to.
> Ideally, it would also have a microphone
> so it could listen to itself, me (via a
> whistle), and other Stamps.
> What is the best approach? The Piezo
> approach seems limited in controllable
> volume -- maybe I'm missing something?
> The Speaker approach seems to take a lot
> of power, which isn't a problem if needed.
> I don't have a problem using transistors,
> op-amps, whatever to control the volume,
> I'm just looking for a start. And oh,
> yes, it should be small (3" square max) [noparse];)[/noparse]
    You could always get one of those $10 amp kits from Ramsey and amplify the
    sounds you can get out of the Stamp pin. With a digital pot you could
    probably even adjust the volume level too... I think you can even snag a
    copy of their schematic out of their documentation.
    transistor
    Texas
    with
    > > it to.
