Math with the BS2
I am new to the Basic Stamp.
I am trying to take a pressure reading through the LTC1298 ADC
I get the input fine.
The problem is when I try to do the math to convert the pressure to mb.
I am using the formula:
pressure=AD*p01/p02+p03
where p01=137
p02 = 591
and p03 = 512
AD ranges in value from about 1100 to 2400
with AD = to about 2130 My output should read 1005
Instead, I am getting a reading of 567
I have tried using numbers instead of variables as well as the
following lines.
pressure=AD*p01
pressure=pressure/p02
pressure=pressure+p03
All result in the same incorrect answer.
where p01=137
p02 = 591
and p03 = 512
following lines.
pressure=AD*p01
suggestions. If p01, p02, and p03 are constants - that is they do not
change, why not figure out what p01/p02+p03 equals and multiply AD by that.
That would eliminate alot of math from your BS2. Also, not sure of specifics
with BS2 but most computers handle division before addition. I believe the
precedence goes mult, div, add, subtract. This would greatly affect the
outcome of your equation. If indeed you do want p01/p02 done first this
yields 0.2318... again I'm not sure how the bs2 handles number this small
perhaps rounds to nearest integer (0 or 1).
Hope this helps
Sent: Wednesday, March 12, 2003 9:11 PM
Subject: [noparse][[/noparse]basicstamps] Math with the BS2
> where p01=137
> p02 = 591
> and p03 = 512
> following lines.
> pressure=AD*p01
pressure = AD ** 15192 + 512
The Stamp approximates your fraction, 137/591, with this one:
15192/65536. The division by 65536 is implied in the ** operator.
In straight multiplication, 2130*137 would be 291810, but the Stamp
gets it wrong, 29666, because of its 16-bit word size. The **
operator avoids the problem.
-- Tracy
>where p01=137
>p02 = 591
>and p03 = 512
>following lines.
>pressure=AD*p01
