Opto 22 — Parallax Forums
Opto 22
edited 2003-03-18 01:47 in General Discussion
Has anyone had any experience with the OPTO 22 relay board?
Parallax has a baord for it on back rder, but I'd like my kids to use
one now. They experimented with using the Stamp to operate it.
The Stamp can turn on the relay's LED, but not close the relay
contacts.
I assume it is just a matter of current, but would like to see what
others have doen first. I have some spare ULN2803s to use in the
project.
Paul
    edited 2003-03-13 14:42
    Check Ebay.
    Paul
    Sent: Wednesday, March 12, 2003 6:37 AM
    Subject: [noparse][[/noparse]basicstamps] OPTO 22
    > contacts.
    > project.
    > Paul
    edited 2003-03-13 18:26
    Paul, I have used opto22 modules for many applications. The best way to
    drive them with the stamp is to use an additional transistor on the output
    to trigger the module. This takes the load off the stamp and the drive for
    the opto comes from another power supply. For an example how to wire up the
    transistors, check out my web site.
    http://geocities.com/jimforkin2003/index.html
    jim
    From: galt1x [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Y0tcF7ck1H7JHFg6-Cfby7n-tCIZnf3_MiIrcpSgMLmuxEO5j6BDj9XY3lnUcz7enz-5ke2l4m0]galt1x@a...[/url
    Sent: Thursday, March 13, 2003 9:43 AM
    Subject: Re: [noparse][[/noparse]basicstamps] OPTO 22
    Check Ebay.
    Paul
    > contacts.
    > project.
    > Paul
    edited 2003-03-16 18:22
    I may be wrong but if the Opto 22 was for AC loads then applying power to
    the LED side will not cause the output to conduct without present of AC.
    Bucky
    > contacts.
    > project.
    > Paul
    edited 2003-03-17 14:40
    Opto22 is a brand name and consists of several different modules some of
    which are for switching dc, ac, and ac input and dc input modules and all
    supporting boards, power supplies, control modules and such.
    Jim
    From: bucky [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qNP3MW_1qtPiiLIIcO_iyKNL6B4thWanPKcDj6AorCLc_GOc6EziyGu5tHWaQM9HXGnhMD4Iz541wXU]buckys@a...[/url
    Sent: Sunday, March 16, 2003 1:22 PM
    Subject: RE: [noparse][[/noparse]basicstamps] OPTO 22
    Bucky
    > contacts.
    > project.
    > Paul
    Paul,
    I found a FAQ here:
    (http://www.opto22.com/support/optofaq/faq220.asp)
    That reads:
    Product Support FAQ and Technical Reference
    2.20 - SSR Applications subFAQ
    Q: What is a solid-state relay?
    A: An SSR is a semiconductor device that can be used in place of a
    mechanical relay to switch electricity to a load in many applications.
    Solid-state relays are purely electronic, normally composed of a low current
    "control" side (equivalent to the coil on an electromechanical relay) and a
    high-current load side (equivalent to the contact on a conventional relay).
    SSRs typically also feature electrical isolation to several thousand volts
    between the control and load sides. Because of this isolation, the load side
    of the relay is actually powered by the switched line; both line voltage and
    a load (not to mention a control signal) must be present for the relay to
    operate.
    Which confirms my earlier statement.
    bucky
    From: bucky [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BNsoXCPdkhC5edwb4JDCh0FWMj_MfqRT2Va0HraMan6HiIexrWk34o8FXklKZJEgpMefz9v-IS3q]buckys@a...[/url
    Bucky
    > contacts.
    > project.
    > Paul
