Servo voltage questions
Would upping the voltage from 4.8 to 6 to 7.2 yield a noticable
increase in speed of the servo?
I take it a servo wouldn't be able to take much more than 7.2, if
that...
I'm using the parallax continuous servos.
that...
Shack 7.2V 2AH battery pack used in RC models. The servos do turn a
little faster but other than that I have had no adverse effects.
Hal
--- In basicstamps@yahoogroups.com, "justin21885" <justin21885@y...>
> that...
Yes - if it survives that voltage.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 19 years of Engineering Innovation (1984 - 2003)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
>that...
As several of you have replied, this is possible, but it seems to
be questionable if upping the voltage will or will not harm the servo.
The answer eventually would be yes, more voltage = more wear and tear,
electronics, gears, etc.
There is however a method that I have used before that will at least
preserve the electronics of the servo, not necessarily the motor.
High Power Driver - Servo Motor:
http://www.angelfire.com/wizard/y2kbc/schematic/hpd_sm.gif
Here is a view of a similar modification, recycling the driver electronics
in an old SERVO to be used as an ESC (Electronic Speed Control) for a much
more robust motor. This modification was also done for the steering on the
same remote control car by using the existing steering gearbox and coupling
a feedback potentiometer to the gearbox.
http://www.angelfire.com/wizard/y2kbc/schematic/car-hack.jpg
i would'nt go above the normal 5 volt supply level.
--- Dwayne Reid <dwayner@p...> wrote:
> a noticable
> dwayne
> CANADA
> - 2003)
> email address.
> unsolicited
> commercial email.
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Web Hosting - establish your business online
http://webhosting.yahoo.com
