INL Command
Ok, I'm trying to get a good understanding of the INS,INL,INH
functions or commands in PBASIC or within the BS2SX IC. I'm trying
to continuously check the status of the first inputs(1-8) on the
activity board(Port X7). When 2 of the pins go high, I want to use
the IF...THEN statement to do other things. But I can't seem to
check the INL or the inputs correctly. Can someone help me with this
problem? Thank You
Another question, on the activity board, port X7 shows pins 1-20.
Does it really mean pins 0-19? ...like pin1 is really pin0 for
programming purposes??? Thanks...someone please help me out
problem? Thank You
the_prettiest@h... writes:
> problem? Thank You
You want to do what is called bit masking.......
Write and AND statement to check the bits that you want to view.
example
if you want to check bits 0 and 1 but actually looking at the first 8 bits
(INL)
My syntax is probably wrong, but the idea is this:
Assing a variable to INL, for example Low_byte
code:
Low_byte = INL
Low_byte = Low_byte AND 00000011
Now perform your IF test on Low_byte
If both bits of INL were high, Low_byte will equal 3 (decimal)
If only bit 1 was high, Low_byte will equal 2.(decimal)
If only bit 0 was high, Low_byte will equal 1.(decimal)
Many other "stampers" will indeed correct my syntax if it is incorrect, and
likely give you a better way to do it. This solution is only one of many.
Ken
> In a message dated 3/11/2003 7:37:55 PM Pacific Standard Time,
trying
use
this
> > problem? Thank You
20.
> example
8 bits
> (INL)
> code:
> Low_byte = INL
incorrect, and
many.
> Ken
Thanks Ken! This clears up a lot. So I must setup a variable that's
equal to INL? Ok, I'm checking 8 inputs only. At any time, any one
of those 8 inputs may go high, but only 2 go high at a time and they
only stay high for 1 second before going back low. I must
continuously read or check these inputs and make sure that I catch
them when they go high. So, with this being the case, should I start
out with something like:
Low_Byte = INL
Low_Byte = Low_Byte AND 11111111
IF Low_Byte = 9 THEN Label-On 'Bits 0 and 3 go high
Would this be correct? Would I need to use INA, INB, INC, IND? Thanks
for your help...all of you...Thanks
> Low_Byte = INL
From what I see, you correctly understood my explanation.
The example you listed will indeed check the status of all 8 bits, and you
are correct when you stated:
"IF Low_Byte = 9 THEN Label-On 'Bits 0 and 3 go high"
You can use INA if you want to check only input pins 0 through 3. INB equates
to input pins 4 through 7, INC = bits 8 ~ 11 and of course, IND = bits 12 ~
15.
Or, INL will check pins 0 ~ 7, INH is pins 8 ~ 15. (if I remember correclty -
I don't use the stamp much these days)
Also, since your "two pins" will remain high for only one second, you program
loop should continuously check INL. The loop itself probably takes i500 to
600 uS or less to complete, so you should have no problem "missing" the high
state of both pins.
> In a message dated 3/12/2003 6:34:31 AM Pacific Standard Time,
that's
one
they
catch
start
> > Low_Byte = INL
and you
INB equates
bits 12 ~
> 15.
correclty -
you program
i500 to
> state of both pins.
Thanks a lot! Ok, I'm dealing with X-10, the XOUT command, and it
seems to slow down the process a little, unless I had things setup
wrong which caused this. When certain pins go high, I want to
perform a certain XOUT command. Ok, so could you give me an example
of how the top portion, the variable declarations section, would look
for what I have going on? Or do I basically have it already? Will I
need to declare anything as INL or will the Low_Byte = INL do? What
would I declare Low_Byte as in the declarations? Thanks for all of
your help. It also seems like when I put my wires into the board,
the program seems to quit running or something. I'm using the
Activity Board. The input port, (X7) has pins 1-20, does it really
mean 0-19...for programming purposes? ...is my first pin pin1 or
pin0? Ok...I know that's a lot of questions...I'm sorry about that,
but if you could answer each of them I would really appreciate it,
really. Thanks in advance.
I am not familiar with the "activity board" and input port X7, and pins 1-20.
Sorry for that. I am sure there are some "stampers" out there that will be
able to help you in that area.
Generally, from what I know, when talking about software, the least
significant bit is bit 0. So the lowest eight bits are bits 0 through bit 7
(first 8 bits)
Regarding the top portion of your program for variable declaration, the
following can be used to check the state of input pins 0 through 7.
Low_byte var byte 'defines variable Low_byte as 8 bits
mask var byte 'defines variable mask as 8 bits
mask = $FF 'assigns value %11111111 to mask
loop:
Low_byte = INL 'moves contents of INL into variable
Low_byte
Low_byte = Low_byte AND mask 'returns which bits of INL were high
'perform your IF statement to check any
number of bits
more code etc.
I hope this helps
Ken
smartdim@a... writes:
> loop:
> Low_byte 'OMIT THIS LINE
> number of bits
> more code etc.
> I hope this helps
> Ken
