LED resistor: smaller value = brighter? — Parallax Forums
edited 2003-03-10 23:22 in General Discussion
I've been working on a project invovling MIDI & illuminated buttons
(thanks again to those who answered my previous questions, everything
is working great so far!)
I put in 470 Ohm resistors between stamp pins & the LEDs in the
buttons because that is what everybody seems to be using. But I'd
like the LEDs to be a little brighter. IF I use a 220 Ohm resistor
instead will the LEDs be brighter? They're just standard LEDs inside
the buttons.
Because I'm lighting up to 5 LEDs at once, I've got a darlington
array in there, and I'm using a voltage regulator (not the one on the
BS2)
Any help appreciated, and if anybody else is building a talkback
system for a Yamaha 01v I'll be happy to share some sysex codes....
-DL
    edited 2003-03-10 18:54
    Yes, the LED will get brighter with more current,
    (less resistance)
    until around 20 to 35 mA (depending on the LED),
    when it becomes very bright for a short time and
    burns out. Most 'normal' LEDs will do 25 mA.
    The standard LED equation is:
    (VCC - Vled) / SeriesResistance == LEDCurrent.
    (5 Volts - 1.4 Volt LED) / 25 mA == 144 ohms.
    So, 144 ohms is the SMALLEST resistance.
    Note from 15 to 25 mA you don't see a lot of
    difference in intensity.
    (5 volts - 1.4 volt LED) / 220 ohms == 16 mA,
    which would be typical (and safe).
    Note the Stamp maxes out at 60 mA total for all I/O
    pins added together -- but you mention darlingtons,
    so you know about that.
    --- In basicstamps@yahoogroups.com, "futilityengineer"
    everything
    inside
    > the buttons.
    the
    > BS2)
    > -DL
    edited 2003-03-10 18:56
    Dropping the resitance will make the LED brighter. However, you may
    also overdrive the LED and burn it out.
    With regards to driving LED's you need to know what voltage and
    current the LED is rated at. And, with these two values you can
    determine the optimum value for your resistor that will be required
    based on you supply voltage. This optimum value will give you
    maximum brightness for that LED, without burning it out.
    The way you determine this value is described in great detail on Al
    Williams site at http://www.wd5gnr.com/basiccir.htm
    But, basically, you can use the folowing formula:
    Supply Voltage - Rated Dropout Voltage of the LED
    Rated current used by the LED (amps)
    For example, say you have an LED rated at 1.2V@10mA and you have a
    supply voltage of 5 then you have:
    5 - 1.2 3.8
    = --- = 380 ohms
    .01 .01
    All this is great assuming you know the values in which the LED is
    rated. If not, stick with the 470 ohm resistors so you can be safe
    not to burn them out.
    -Dustin
    everything
    inside
    > the buttons.
    the
    > BS2)
    > -DL
    edited 2003-03-10 18:58
    You can make the resistor value smaller provided you do not excede the
    maximum current allowed. Most LED's will tolerate 20ma. but you must check
    your particular ones. Use ohm's law to determine the resistor value to use.
    divide the supply voltage by the current to get the resistance. For example
    5 volts devided by .02 amps (20 ma.)= 250 ohm so 220 ohm resistors would
    exceed the 20 ma. rating. By the way, you want to have a separate resistor
    for each LED, not a common one for all the LED's.
    From: futilityengineer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LdmAaggTc0ejO5TK1OGsBPZCmA_fFWg8Tnj7kXolVdhjiecAOWfzGk8pcvCkrVNviJY1OUIKdAwLpB_E6BtDNJ9P4Hs]futilityengineer@y...[/url
    Sent: Monday, March 10, 2003 1:29 PM
    Subject: [noparse][[/noparse]basicstamps] LED resistor: smaller value = brighter?
    the buttons.
    BS2)
    -DL
    edited 2003-03-10 18:59
    I drive a laser diode with a stamp pin to one channel of a ULN2803
    darlington array, and use the 2803 output to ground the diode and turn
    it on (a pull-up resistor is also used). I vary the diode intensity
    independently with a small-valued pot (or fixed R) in series with the
    +5v power to the diode.
    Dennis
    From: futilityengineer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BOOmnB6Aw92prQLPEpBGIUYvw-xVHEWa1oEEWltwYuW1ovZfUEnDJANAJfF0ne-AaZr-5KskaY98rj3_IXmBZqU]futilityengineer@y...[/url
    Sent: Monday, March 10, 2003 10:29 AM
    the buttons.
    BS2)
    -DL
    edited 2003-03-10 22:55
    I had a similar problem and burned up several LEDs trying to get them
    extra bright.. Use a lower value resistor, I wouldn't go under 180
    ohms or so, and use the PWM command to control the apparent
    brightness of the LED. Since you're pulsing the LED very fast, and
    it's off for a short period of time between each on pulse, it has
    time to cool off and recover. You can adjust the PWM amount to get a
    nice 'twinkle' from the LED. Radar transmitters use this same
    principle to get many thousands of watts from a device that's only
    capable of a couple hundred watts in continuous operation. It's
    called 'duty cycle.'
    -Jorth-
    everything
    inside
    > the buttons.
    the
    > BS2)
    > -DL
    Yup, you can get some serious light out of an LED when you do it right. We
    did the same thing with a standard 3-volt flashlight bulb way back when.
    Pumped it with 9 volts for a *very* brief period of time and it was bright
    enough to see from 2-3 blocks away.
    You could always break down and buy some super-bright LED's. These things
    are fairly bright even when pulsed, and you don't need to push them to their
    max rating to do it. I've got some T1-sized LED's I used to replace some
    small 12-volt bulbs. I run them at their rated current and they are way
    brighter than the bulb -- so much so they almost blind you at night.
    > everything
    > inside
    > > the buttons.
    > the
    > > BS2)
