Input command THANKS — Parallax Forums
edited 2003-03-09 19:14 in General Discussion
It Works,
Thanks Sid
Bob Phillips
> [noparse][[/noparse]Original Message]
> From: <Newzed@a...>
> To: <basicstamps@yahoogroups.com>
> Date: 3/9/2003 1:38:37 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Input command
> In a message dated 03/09/2003 13:18:19 Eastern Standard Time,
robertp@v...
> writes:
> > Yes, I am using the correct input (pin)=1 command, I just didn't say it
in
> > the message.
> Then the next thing is to just set the pin high - don't pulse it. If you
> pulse it, by the time the program getss to the loop the pulse is gone and
pin
> = 0.
> Sid
> [noparse][[/noparse]Non-text portions of this message have been removed]
    In a message dated 03/09/2003 14:06:04 Eastern Standard Time, robertp@v...
    writes:
    > It Works,
    > Thanks Sid
    You are very welcome. Anytime.
    Sid Weaver
    W4EKQ
    Port Richey, FL
