Input command
Hi All,
I'm sending a signal to a input on a stamp, its a very short burst of
+voltage (I have a LED hooked up in parallel so I can see the pulse) I'm
using a "input=1 then" in a loop to see it, I have also tried the button
command"
My problem is that some times the program doesn't see the burst of
+voltage, is their a latching type of input command or a hold for one
second to see the voltage ??
Bob
command"
Bob
writes:
> command"
You have to say 'in(pin) = 1 then......
If you are inputting to pin 0 then write
if in0 = 1 then......
Sid
the message.
Bob Phillips
> [noparse][[/noparse]Original Message]
> From: <Newzed@a...>
> To: <basicstamps@yahoogroups.com>
> Date: 3/9/2003 12:48:06 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Input command
> In a message dated 03/09/2003 12:31:14 Eastern Standard Time,
robertp@v...
> writes:
I'm
button
> > command"
> Sid
writes:
> Yes, I am using the correct input (pin)=1 command, I just didn't say it in
> the message.
Then the next thing is to just set the pin high - don't pulse it. If you
pulse it, by the time the program getss to the loop the pulse is gone and pin
= 0.
Sid
