reading dipswitches (revisited)
Thank you all for the reponses to my previous post, but I just
realized I might be hooking it up wrong from the start....
I have one side of each dipswitch hooked to its own i/o pin (set to
input) and the other side set to ground. Won't that do...nothing at
all? It seems to me that I have it hooked up in a way that there
isn't any current to flow into those input pins, to be detected.
Should I instead have one end of each switch connected to an INPUT pin
and the other and connected to an OUTPUT pin?
And if so, can I connect all four to the SAME output pin?
thanks again,
--Alex
thanks again,
--Alex
You'll need some pullup resistors on your input pins to make the input
high when the dip switch isn't closed to ground. 10k should do.
HTH.
Mos.
84 AE86, 90 ST185GrpA, 91 MX83Gr, Sydney, Oz.
> thanks again,
> --Alex
