---DS1302--- timekeeper help please
I am having trouble with a ds1302 timekeeper. I used the
basic code from parallax (below). I loaded the current time and date. What the
debug screen shows is,
" 00:09:01 81/01/81"
I replaced the ds1302 and xtal with a spare, and got the same result. I checked
all the connections and all seem
to be okay......
Has anyone experienced this before ? any help with a solution would be
appreciated.......
Larry
'* Title: DS1302_2.BS2 Author: Jeff A Martin Date: 5/18/98 *
'* Description: Shortened version of DS1302_1.BS2. *
DATA (49)
RTCCmd VAR BYTE
Clk CON 0
Dta CON 1
RTCReset CON 2
Temp VAR BYTE
Seconds VAR BYTE
Minutes VAR BYTE
Hours VAR BYTE
Date VAR BYTE
Month VAR BYTE
Year VAR BYTE
I VAR BYTE
'Define Constants
SecReg CON %00000
MinReg CON %00001
HrsReg CON %00010
DateReg CON %00011
MonReg CON %00100
YrReg CON %00110
CtrlReg CON %00111
BrstReg CON %11111
DIRS = %0000000000111111
OUTS = %0000000000000000
' Clear Write Protect bit in control register
Temp = $10 '
RTCCmd = CtrlReg
GOSUB WriteRTC
Temp = $03 'year
RTCCmd = YrReg
GOSUB WriteRTC
Temp = $10 'hours
RTCCmd = HrsReg
GOSUB WriteRTC
Temp = $01 'month
RTCCmd = MonReg
GOSUB WriteRTC
Temp = $23 'date
RTCCmd = DateReg
GOSUB WriteRTC
Temp = $33 'minutes
RTCCmd = MinReg
GOSUB WriteRTC
Temp = $55 'seconds
RTCCmd = SecReg
GOSUB WriteRTC
Temp = $00 '
RTCCmd = CtrlReg
GOSUB WriteRTC
GOSUB ReadRTCBurst
DEBUG HOME, cr,cr,cr,cr," ",DEC Hours.HIGHNIB,DEC Hours.LOWNIB,":",DEC
Minutes.HIGHNIB
DEBUG DEC Minutes.LOWNIB,":",DEC Seconds.HIGHNIB,DEC Seconds.LOWNIB
DEBUG " ",DEC Month.HIGHNIB,DEC Month.LOWNIB,"/"
DEBUG DEC Date.HIGHNIB, DEC Date.LOWNIB,"/",DEC Year.HIGHNIB, DEC Year.LOWNIB,CR
WriteRTCRAM:
'Write to DS1202 RTC
HIGH RTCReset
SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%11\2,Temp]
LOW RTCReset
RETURN
WriteRTC:
HIGH RTCReset
SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%10\2,Temp]
LOW RTCReset
RETURN
ReadRTCBurst:
HIGH RTCReset
SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours,Date,Month,Year,Year]
LOW RTCReset
RETURN
ReadRTCRAM:
HIGH RTCReset
SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,RTCCmd\5,%11\2]
SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Temp]
LOW RTCReset
RETURN
to be okay......
appreciated.......
Larry
DATA (49)
RTCCmd VAR BYTE
Clk CON 0
Dta CON 1
RTCReset CON 2
Temp VAR BYTE
Seconds VAR BYTE
Minutes VAR BYTE
Hours VAR BYTE
Date VAR BYTE
Month VAR BYTE
Year VAR BYTE
I VAR BYTE
'Define Constants
SecReg CON %00000
MinReg CON %00001
HrsReg CON %00010
DateReg CON %00011
MonReg CON %00100
YrReg CON %00110
CtrlReg CON %00111
BrstReg CON %11111
Temp = $10 '
RTCCmd = CtrlReg
GOSUB WriteRTC
Temp = $03 'year
RTCCmd = YrReg
GOSUB WriteRTC
Temp = $10 'hours
RTCCmd = HrsReg
GOSUB WriteRTC
Temp = $01 'month
RTCCmd = MonReg
GOSUB WriteRTC
Temp = $23 'date
RTCCmd = DateReg
GOSUB WriteRTC
Temp = $33 'minutes
RTCCmd = MinReg
GOSUB WriteRTC
Temp = $55 'seconds
RTCCmd = SecReg
GOSUB WriteRTC
Temp = $00 '
RTCCmd = CtrlReg
GOSUB WriteRTC
GOSUB ReadRTCBurst
Minutes.HIGHNIB
WriteRTCRAM:
HIGH RTCReset
LOW RTCReset
RETURN
WriteRTC:
HIGH RTCReset
LOW RTCReset
RETURN
ReadRTCBurst:
HIGH RTCReset
LOW RTCReset
RETURN
ReadRTCRAM:
HIGH RTCReset
LOW RTCReset
RETURN
forked_river@w... writes:
> the debug screen shows is,
What did you load?
Sid
i have used the clock chip in the past and the code was cleared of some
bugs a long time ago when i couldn't get it to work either. this was done
by Parallax. it works fine now. i will try and find the floppy with the
code ASAP and post it for you. I also found that in order to maintain the
battery backup line you needed to put a 10k on the RST line too which was at
the time not shown on the original app note. The code that i was fortunate
to get from Parallax was one that let you put switches in the BS2 to set the
time just like a simple digital clock with a blinking cursor. It worked
great. Hold tight and I will find the floppy and post it. Just have to
find the right one in a mass of BS2 confusion. If you need help
immediately, contact me directly at:
mocenter@e...
mike m
Sent: Wednesday, March 05, 2003 10:45 AM
Subject: [noparse][[/noparse]basicstamps] ---DS1302--- timekeeper help please
checked all the connections and all seem
> to be okay......
appreciated.......
> Larry
> DATA (49)
> RTCCmd VAR BYTE
> Clk CON 0
> Dta CON 1
> RTCReset CON 2
> Temp VAR BYTE
> Seconds VAR BYTE
> Minutes VAR BYTE
> Hours VAR BYTE
> Date VAR BYTE
> Month VAR BYTE
> Year VAR BYTE
> I VAR BYTE
> 'Define Constants
> SecReg CON %00000
> MinReg CON %00001
> HrsReg CON %00010
> DateReg CON %00011
> MonReg CON %00100
> YrReg CON %00110
> CtrlReg CON %00111
> BrstReg CON %11111
> Temp = $10 '
> RTCCmd = CtrlReg
> GOSUB WriteRTC
> Temp = $03 'year
> RTCCmd = YrReg
> GOSUB WriteRTC
> Temp = $10 'hours
> RTCCmd = HrsReg
> GOSUB WriteRTC
> Temp = $01 'month
> RTCCmd = MonReg
> GOSUB WriteRTC
> Temp = $23 'date
> RTCCmd = DateReg
> GOSUB WriteRTC
> Temp = $33 'minutes
> RTCCmd = MinReg
> GOSUB WriteRTC
> Temp = $55 'seconds
> RTCCmd = SecReg
> GOSUB WriteRTC
> Temp = $00 '
> RTCCmd = CtrlReg
> GOSUB WriteRTC
> GOSUB ReadRTCBurst
Minutes.HIGHNIB
Year.LOWNIB,CR
> WriteRTCRAM:
> HIGH RTCReset
> LOW RTCReset
> RETURN
> WriteRTC:
> HIGH RTCReset
> LOW RTCReset
> RETURN
> ReadRTCBurst:
> HIGH RTCReset
> LOW RTCReset
> RETURN
> ReadRTCRAM:
> HIGH RTCReset
> LOW RTCReset
> RETURN
SETTING the Write-Protect bit ($10), instead of
CLEARING it ($00) -- so in theory none of your
writes will work...
Note that a 'cleared' 1302 reads:
Sunday, Jan 01, 2000, 12:00:80 AM
or: Day 1, Month 1, Date 1, Year 00, Hour 12,
Minute 00, Second 80.
I used program DS1302_1.BS2 from the same source, and it
works very well.
--- In basicstamps@yahoogroups.com, "Lawrence Freeze"
date. What the debug screen shows is,
result. I checked all the connections and all seem
> to be okay......
would be appreciated.......
> Larry
> DATA (49)
> RTCCmd VAR BYTE
> Clk CON 0
> Dta CON 1
> RTCReset CON 2
> Temp VAR BYTE
> Seconds VAR BYTE
> Minutes VAR BYTE
> Hours VAR BYTE
> Date VAR BYTE
> Month VAR BYTE
> Year VAR BYTE
> I VAR BYTE
> 'Define Constants
> SecReg CON %00000
> MinReg CON %00001
> HrsReg CON %00010
> DateReg CON %00011
> MonReg CON %00100
> YrReg CON %00110
> CtrlReg CON %00111
> BrstReg CON %11111
> Temp = $10 '
> RTCCmd = CtrlReg
> GOSUB WriteRTC
> Temp = $03 'year
> RTCCmd = YrReg
> GOSUB WriteRTC
> Temp = $10 'hours
> RTCCmd = HrsReg
> GOSUB WriteRTC
> Temp = $01 'month
> RTCCmd = MonReg
> GOSUB WriteRTC
> Temp = $23 'date
> RTCCmd = DateReg
> GOSUB WriteRTC
> Temp = $33 'minutes
> RTCCmd = MinReg
> GOSUB WriteRTC
> Temp = $55 'seconds
> RTCCmd = SecReg
> GOSUB WriteRTC
> Temp = $00 '
> RTCCmd = CtrlReg
> GOSUB WriteRTC
> GOSUB ReadRTCBurst
Hours.LOWNIB,":",DEC Minutes.HIGHNIB
Year.LOWNIB,CR
> WriteRTCRAM:
> HIGH RTCReset
> LOW RTCReset
> RETURN
> WriteRTC:
> HIGH RTCReset
> LOW RTCReset
> RETURN
> ReadRTCBurst:
> HIGH RTCReset
> LOW RTCReset
> RETURN
> ReadRTCRAM:
> HIGH RTCReset
> LOW RTCReset
> RETURN
Larry
Sent: Wednesday, March 05, 2003 12:05 PM
Subject: Re: [noparse][[/noparse]basicstamps] ---DS1302--- timekeeper help please
> Dear Larry,
the
at
fortunate
the
> mocenter@e...
> mike m
> From: Lawrence Freeze <forked_river@w...>
What
> > to be okay......
> appreciated.......
> > Larry
> > DATA (49)
> > RTCCmd VAR BYTE
> > Clk CON 0
> > Dta CON 1
> > RTCReset CON 2
> > Temp VAR BYTE
> > Seconds VAR BYTE
> > Minutes VAR BYTE
> > Hours VAR BYTE
> > Date VAR BYTE
> > Month VAR BYTE
> > Year VAR BYTE
> > I VAR BYTE
> > 'Define Constants
> > SecReg CON %00000
> > MinReg CON %00001
> > HrsReg CON %00010
> > DateReg CON %00011
> > MonReg CON %00100
> > YrReg CON %00110
> > CtrlReg CON %00111
> > BrstReg CON %11111
> > Temp = $10 '
> > RTCCmd = CtrlReg
> > GOSUB WriteRTC
> > Temp = $03 'year
> > RTCCmd = YrReg
> > GOSUB WriteRTC
> > Temp = $10 'hours
> > RTCCmd = HrsReg
> > GOSUB WriteRTC
> > Temp = $01 'month
> > RTCCmd = MonReg
> > GOSUB WriteRTC
> > Temp = $23 'date
> > RTCCmd = DateReg
> > GOSUB WriteRTC
> > Temp = $33 'minutes
> > RTCCmd = MinReg
> > GOSUB WriteRTC
> > Temp = $55 'seconds
> > RTCCmd = SecReg
> > GOSUB WriteRTC
> > Temp = $00 '
> > RTCCmd = CtrlReg
> > GOSUB WriteRTC
> > GOSUB ReadRTCBurst
> Minutes.HIGHNIB
> Year.LOWNIB,CR
> > WriteRTCRAM:
> > HIGH RTCReset
> > LOW RTCReset
> > RETURN
> > WriteRTC:
> > HIGH RTCReset
> > LOW RTCReset
> > RETURN
> > ReadRTCBurst:
> > HIGH RTCReset
> > LOW RTCReset
> > RETURN
> > ReadRTCRAM:
> > HIGH RTCReset
> > LOW RTCReset
> > RETURN
and
Thanks for the info. I made the change to 00, and unfortunatly got the same
result..
Larry
Sent: Wednesday, March 05, 2003 1:10 PM
Subject: [noparse][[/noparse]basicstamps] Re: ---DS1302--- timekeeper help please
> Well, your first GOSUB RTCWrite looks like it is
> writes will work...
> works very well.
> > to be okay......
> > Larry
> > DATA (49)
> > RTCCmd VAR BYTE
> > Clk CON 0
> > Dta CON 1
> > RTCReset CON 2
> > Temp VAR BYTE
> > Seconds VAR BYTE
> > Minutes VAR BYTE
> > Hours VAR BYTE
> > Date VAR BYTE
> > Month VAR BYTE
> > Year VAR BYTE
> > I VAR BYTE
> > 'Define Constants
> > SecReg CON %00000
> > MinReg CON %00001
> > HrsReg CON %00010
> > DateReg CON %00011
> > MonReg CON %00100
> > YrReg CON %00110
> > CtrlReg CON %00111
> > BrstReg CON %11111
> > Temp = $10 '
> > RTCCmd = CtrlReg
> > GOSUB WriteRTC
> > Temp = $03 'year
> > RTCCmd = YrReg
> > GOSUB WriteRTC
> > Temp = $10 'hours
> > RTCCmd = HrsReg
> > GOSUB WriteRTC
> > Temp = $01 'month
> > RTCCmd = MonReg
> > GOSUB WriteRTC
> > Temp = $23 'date
> > RTCCmd = DateReg
> > GOSUB WriteRTC
> > Temp = $33 'minutes
> > RTCCmd = MinReg
> > GOSUB WriteRTC
> > Temp = $55 'seconds
> > RTCCmd = SecReg
> > GOSUB WriteRTC
> > Temp = $00 '
> > RTCCmd = CtrlReg
> > GOSUB WriteRTC
> > GOSUB ReadRTCBurst
> Year.LOWNIB,CR
> > WriteRTCRAM:
> > HIGH RTCReset
> > LOW RTCReset
> > RETURN
> > WriteRTC:
> > HIGH RTCReset
> > LOW RTCReset
> > RETURN
> > ReadRTCBurst:
> > HIGH RTCReset
> > LOW RTCReset
> > RETURN
> > ReadRTCRAM:
> > HIGH RTCReset
> > LOW RTCReset
> > RETURN
I loaded the following. I also tried loading different combinations of times
and dates to see if the errors followed a pattern. They did not...
Temp = $03 'year
Temp = $10 'hours
Temp = $01 'month
Temp = $23 'date
Temp = $33 'minutes
Temp = $55 'seconds
Larry
---- Original Message
Sent: Wednesday, March 05, 2003 11:10 AM
> In a message dated 03/05/2003 10:55:40 Eastern Standard Time,
What
> What did you load?
> Sid
which isn't going to work. I'm going to try to attach a program that does
work. If you dopn't get the attachment, contact me off line. The list might
not accept attachments.
Sid
'{$STAMP BS2}
'{$PBASIC 2.0}
' File : Stamp Clock_Display V1.5.1
' Date : 04/06/02
' Use with Clock_Temp Display V1.5.1
' Version: V1.5.1
'For use with PC Board. May be breadboarded.
' DS1302 Function Pin Notes
' 1 +5
' 2 Xtal
' 3 Xtal
' 4 Ground
' 5 Rst B.5 Pull down to ground through 10K
' 6 Dio B.6 Connect to bus through 1K if bus is shared
' 7 Clk B.7
' 8 Vcc2 Not used
[noparse][[/noparse] Constants ]
N9600 con 16468
N2400 CON 16780
Clock con 15 ' DS1302.7
Dio con 14 ' DS1302.6
Rst con 13 ' DS1302.5
tempin con 12
red con 11
dataout con 9
WrBrst CON $BE ' same as 190
RdBrst CON $BF ' same as 191
T24hr CON 0
T12hr CON 1
AM CON 0
PM CON 1
[noparse][[/noparse] Variables ]
x var word
secs var byte
mins var byte
hrs var byte
date var byte
month var byte
day var byte
year var byte
ctrl var byte
tMode var hrs.Bit7
tempstr var byte(3)
timestr var byte(6)
oldSc var byte
com var byte(2)
newtemp var word
[noparse][[/noparse] EEPROM Data ]
'Day1 DATA "Sun"
'Day2 DATA "Mon"
'Day3 DATA "Tue"
'Day4 DATA "Wed"
'Day5 DATA "Thu"
'Day6 DATA "Fri"
'Day7 DATA "Sat"
[noparse][[/noparse] Initialization ]
oldSc = $99
[noparse][[/noparse] Main Code ]
Serout 16, N9600, [noparse][[/noparse]"Press 1 to read time", 13,10]
serout 16, N9600, [noparse][[/noparse]"Press 2 to reset time ",13,10]
serin 16, N9600, [noparse][[/noparse]com]
begin:
if com = "2" then newtime 'Red PB
if com = "1" then telltime 'Black PB
goto begin
newtime:
serout 16, N9600, [noparse][[/noparse]cr,"Enter Hex Month", cr]
serin 16, N9600, [noparse][[/noparse]hex2 com]
month = com
serout 16, N9600, [noparse][[/noparse]cr,"Enter Hex Date", cr]
date = com
serout 16, N9600, [noparse][[/noparse]cr,"Enter Hex Year", cr]
year = com
serout 16, N9600, [noparse][[/noparse]cr,"Enter Hex Hours",cr]
hrs = com
serout 16, N9600, [noparse][[/noparse]cr,"Enter Hex Minutes", cr]
mins = com
serout 16, N9600, [noparse][[/noparse]cr,"Enter Hex Seconds", cr]
serin 16, N9600, [noparse][[/noparse] hex2 com]
secs = com
serout 16, N9600, [noparse][[/noparse]cr,hex2 month, "/", hex2 date, "/", hex2 year, " ", hex2
hrs, ":", hex2 mins, ":", hex2 secs, cr]
set1:
tmode = T24hr
GOSUB SetClk
telltime:
high red
pause 100
low red
GOSUB GetClk
GOSUB ShowTm
EndLp: GOTO telltime
[noparse][[/noparse] Subroutines ]
SetClk: HIGH Rst
SHIFTOUT Dio,Clock,LSBFIRST,[noparse][[/noparse]190]
SHIFTOUT Dio,Clock,LSBFIRST,[noparse][[/noparse] SECS, MINS,hrs]
SHIFTOUT Dio,Clock,LSBFIRST,[noparse][[/noparse]date,month,day,year]
SHIFTOUT Dio,Clock,LSBFIRST,[noparse][[/noparse]CTRL]
LOW Rst
RETURN
GetClk:
HIGH Rst
SHIFTOUT Dio,Clock,LSBFIRST,[noparse][[/noparse]191]
SHIFTIN Dio,Clock,LSBPRE,[noparse][[/noparse]secs,mins,hrs]
SHIFTIN Dio,Clock,LSBPRE,[noparse][[/noparse]date,month,day,year]
SHIFTIN Dio,Clock,LSBPRE,[noparse][[/noparse]CTRL]
LOW Rst
RETURN
ShowTm:
'IF secs = oldSc THEN EndST
ST1:
'FOR idx = 0 TO 2 ' get day name
'Read (Day1+((day-1)*3)+idx), dyStr(idx)
'NEXT
SEROUT 16, N9600, [noparse][[/noparse]"Reading Time", cr]
'SEROUT 16, N9600, [noparse][[/noparse]"Today is: ",str DYSTR\3," ",HEX2 MONTH,"/",HEX2 DATE,
"/", HEX2 YEAR, " ", HEX2 HRS, ":", HEX2 MINS, ":", HEX2 SECS, CR]
'serout 16, N9600, [noparse][[/noparse]hex2 month, "/", hex2 date, "/", hex2 year,cr, hex2 hrs,":",
hex2 mins,":", hex2 secs, cr]
pause 1
serout 16, N9600, [noparse][[/noparse]hex2 hrs, ":",hex2 mins,":", hex2 secs, cr]
pause 5000
oldSc = SECS
EndST:
return
wrote:
> Dear Larry,
Mike,
I too would be interested in that code, if you could
upload it to the group, or e-mail off-group please.
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
my age I am lucky if I find MY floppy, get it?
mike m
Sent: Wednesday, March 05, 2003 5:12 PM
> --- "M. E. M. Electronics" <memelectronics@e...>
> wrote:
> > Dear Larry,
> Mike,
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
OK, I've uploaded the version of the file which works
for me. See the 'Files' section, 1302.bs2.
I had a similar experience to yours -- I tried to use
a program (as a tutorial) which simply didn't work.
I then went to this program, which worked.
Make sure you assign the pins at the start of the program
to the three pins you're using for Data, Clock, and /Reset.
Also, I have an LED on my board at pin 13 -- you may want
to comment out the 'BlinkLED' call. Also, in order to
set the chip you need to comment out the 'GOTO LOOP' which
currently skips the time load section.
The issues with the 1302 are how to write to the chip,
how to read from the chip, and how to interpret the
Binary Coded Decimal values read from the chip.
See the code.
> Allan,
the same
> result..
> Larry
Larry
Sent: Thursday, March 06, 2003 9:39 AM
> Problem: DS1302 interfacing...
> See the code.
> > Allan,
> the same
> > result..
> > Larry
