Serial Input question
Serial In question.
I am having problems decoding serial in data from a Midon Designs
Temp 05 module. (All rates are set up to 9600,8,n,no)
I can send info from a hyper terminal pc to the stamp serial port and
data is properly decoded.
Midon temp 05 module sends serial stream properly to pc hyper
terminal.
The problem is when the temp 05 module is connected to the stamp i/p
all data is 255's.
The Stamp i/p is using an Al Williams RS1 inverter/level shifter.
Anybody had a similar problem??
Code is below
{$STAMP BS2p}
'{$PBASIC 2.0}
'{$PORT COM1}
' testing the ser out and in baud mode # 240 for rs 232 line driver
' 9600 8 no parity
STEST:
SERIN 1, 240, 30000, NODATA, [noparse][[/noparse]SPSTR 10]
' added wait for sensor worked once to trigger but still
garbage on decode.
'LOOKS FOR 10 BYTE SERIAL SCRATCH PAD STRING IF NOTHING IN GO
TO NO DATA
MYBYTES VAR BYTE(10)
INDEX VAR NIB
INDEX=0
FOR INDEX=0 TO 9
'LOOPS BETWEEN FOR AND NEXT THE NUMBER OF INDICATED TIMES
GET INDEX, MYBYTES(INDEX)
`takes scratch pad data and moves it to mybytes
NEXT
'END OF NEXT LOOP AFTER INDEX NUMBER IS EXCEEDED THE PGM
JUMPS OVER NEXT.
INDEX=0
FOR INDEX=0 TO 9
'SETS INDEX TO COUNT O-9
DEBUG ? MYBYTES(INDEX)
'SENDS MYBYTES ARRAY TO DEBUG IN SEQENTIAL ORDER WITH CR
BETWEEN EACH
' USE THIS FOR LOOKING INTO SCRATCH PAD ARRAY. DATA OUT IN
DECIMAL
NEXT
DEBUG STR MYBYTES, CR
'DEBUG STR SHOWS STRING OF DATA CALLED MYBYTES IN ASCCI.
PAUSE 500 'wait 5 seconds
GOTO STEST 'return to top
NODATA:
DEBUG "NO DATA",CR
GOTO STEST
'RESULTANT STRING OF DATA FROM DEBUG.
'MYBYTES(INDEX) = 255
'ÿÿÿÿÿÿÿÿÿÿ
'ACTUAL DATA input.
'Sensor #01=71.70F
terminal.
all data is 255's.
Code is below
{$STAMP BS2p}
'{$PBASIC 2.0}
'{$PORT COM1}
' 9600 8 no parity
STEST:
garbage on decode.
TO NO DATA
INDEX VAR NIB
INDEX=0
FOR INDEX=0 TO 9
NEXT
JUMPS OVER NEXT.
INDEX=0
FOR INDEX=0 TO 9
BETWEEN EACH
DECIMAL
NEXT
NODATA:
DEBUG "NO DATA",CR
GOTO STEST
'ÿÿÿÿÿÿÿÿÿÿ
'ACTUAL DATA input.
'Sensor #01=71.70F
