basic stamps and VB
hi everybody,
i would like to know how i can control a basic stamp using a visual
basic application: sending high and low signals from a VB
application through serial port to a basic stamp.
any suggestions?ideas?
Thanx in advance
Mohammad
Thanx in advance
Mohammad
Serial data is serial data no matter what program produces it and I/O is
I/O. If you take care to produce proper data and limit voltages on the I/O
you can control the stamp with anything including VB. I've built stamp
circuits which are controlled by PLC's, switches, serial data from PC's and
Pocket PC's running windows CE.
Jim
From: jagal1979 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lXRgdg9h8gcbHVhQGe02UV9eIHb3RWsprah5mOA7Qu0guQZoeDIiLL9NCnn5kJkVoir20gE0-dB2F9kC]jagal1979@y...[/url
Sent: Wednesday, March 05, 2003 4:02 AM
Subject: [noparse][[/noparse]basicstamps] basic stamps and VB
hi everybody,
Thanx in advance
Mohammad
do you have any samples where you control a basic
stamp from a VB application? i've never done that and
would appreciate a little push in order to get
started.
Thanx a lot.
Mohammad
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
this article (published in Nuts & Volts magazine):
<A
HREF="http://www.parallax.com/Downloads/Documentation/nv/v3/col/NV89-Data_Exchan\
ge_with_Visual_BASIC.pdf">
http://www.parallax.com/Downloads/Documentation/nv/v3/col/NV89-Data_Exchange_wi
th_Visual_BASIC.pdf</A>
-- Jon Williams
-- Parallax
In a message dated 3/5/2003 11:57:32 AM Central Standard Time,
jagal1979@y... writes:
> Jim,
> started.
> Thanx a lot.
> Mohammad
