problems with CMU cam
Archiver
Michael-
Here's a guess. The ':' is being transmitted while your "debug
"serout done",cr statement is executing, so it has already happened
before your Stamp begins looking for it. Kind of like trying to
catch up with a fast ball that is already in the catcher's mitt. Try
it without that statement and see what happens.
FWIW, DEBUG works at 9600 baud, so each byte/character you transmit
consumes slightly over 1 millisecond. Your DEBUG statement above
would take more than 0.0125 seconds just in transmission time if my
occasionally-reliable arithmetic is correct.
Steve
Steve
A quick look at the Parallax documentation for their version of the CMUcam
shows that their usage of the SEROUT and SERIN commands (that wait for the
colon) do not have any intervening program code.
I suspect that what is happening is that your DEBUG statements take
sufficient time that the CMUcam's response is "lost" in the bit-bucket
before the SERIN command gets started to process (there is no buffer on the
SERIN).
So, Try removing all program code between the SEROUT and the corresponding
SERIN with the "wait" option.
You might also try using the timeout option on the SERIN, if that is
appropriate to your application.
HTH,
Daniel
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CiOVATw6-B_5gAwQ2wDr6QDazCqAFx_Vr2MWRjSNCCqRdfZGOWrxi3TunpzCTjo0CPVtA39ApSmbiHXG]ord_data@h...[/url
Sent: Tuesday, March 04, 2003 4:34 AM
Subject: [noparse][[/noparse]basicstamps] problems with CMU cam
I seem to be having problems with getting a CMU cam to communicate
with BoeBot. I have connected the wires according to the
documentation, transmit on pin 10 and receive on pin9 but for some
reason the program stalls on serin 9,240,[noparse][[/noparse]WAIT (":")] Anyone have
any ideas that could be causing this. I have the whole code below as
it isn't long and is part of initial checks.
-Michael
'{$STAMP BS2p}
'{$PBASIC 2.5}
Initialization beep
output 2
freqout 2, 2000, 2000
Main:
' Flash the tracking LED
' Send command - Turn on track LED
debug "LED test",CR
serout 10, 240, [noparse][[/noparse]"L1 1",CR]
debug "serout done",cr
serin 9, 240, [noparse][[/noparse]WAIT (":")]
debug "serin done",cr
debug "LED on ACK: received OK",CR
' Wait 1/2 second
Pause 500
' Send command - Set track LED back to auto mode
serout 10, 240, [noparse][[/noparse]"L1 2",CR]
serin 9, 240, [noparse][[/noparse]Wait (":")]
debug "LED off ACK: received OK",CR
' Wait 1/2 second
Pause 500
Goto Main
error with the SERIN command, but those weren't originally there
either. I added them to determine whether it was SEROUT or SERIN
that was problematic. That is when I figured that the SERIN is not
responding - could it be a transmission problem on the camera side?
As for the timeout feature, I can implement it on this particular
part but my main program will require information from the camera to
be stored and if SERIN doesn't, it kind of causes problems.
- Michael
--- In basicstamps@yahoogroups.com, "D. Daniel McGlothin" <ddm@m...>
wrote:
> Michael,
CMUcam
for the
bucket
buffer on the
> SERIN).
corresponding
> HTH,
> Daniel
> '{$STAMP BS2p}
> '{$PBASIC 2.5}
Initialization beep
> output 2
> Main:
> debug "LED test",CR
> ' Wait 1/2 second
> Pause 500
> ' Wait 1/2 second
> Pause 500
> Goto Main
Subject and
