setting a pin to float?
Archiver
Does anyone know how to set a pin to float after setting it high or low?
Alina
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, and more
Alina
Do you Yahoo!?
Set that pin as input.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 19 years of Engineering Innovation (1984 - 2003)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
>Thanks,
>Alina
Assuming you are using a BS2, change the "dirs" (direction setting)
for that pin from output to input. Then remember to change it back
again if you need it to assert a LOW or HIGH later in the program.
Reg
Reginald Neale wrote:
> ... change the "dirs" (direction setting)
Don't HIGH and LOW make the pin an output, then set the state?
best regards, Jack
-- Jon Williams
-- Parallax
In a message dated 3/2/2003 8:43:45 PM Eastern Standard Time, goflo@p...
writes:
>Hi Reg -
>best regards, Jack
