Oncore GPS Checksums
Archiver
Jonathan-
It's spelled out in Chapter 3 of the Oncore doc's on page 3.26, and
described as "the exclusive-or of all message bytes after the @@ and
before the checksum". A checksum is formed by combining the
contents of a stream of data in some way. The receiver can verify
the integrity of the captured data by calculating the checksum again
and comparing it with the checksum value received. If they match,
chances are the data were received completely and without error. As
the name implies, this often involves just summing all bytes, but the
Motorola binary format does an exclusive-or (XOR) over the data
instead.
So to use the read date example, you send the following 11-byte
command:
"@@Ac",$ff,$ff,$ff,$ff,checksum,carriage return,linefeed
In this case, the data between the @@ and the checksum are the six
bytes "Ac",$ff,$ff,$ff,$ff. So the checksum could be formed by
XORing 'A', 'c', $ff, $ff, $ff and $ff. But if you look at how XOR
works, you'll see that you get the same result by merely XORing 'A'
with 'c', and you save program memory and typing if you use the
shortcut.
To request time, you send:
"@@Aa",$ff,$ff,$ff,checksum,carriage return,linefeed
The available shortcut in this case is to only XOR the $ff once.
The XOR operation is implemented in your Stamp via the ^ operator,
and is described in the manual better than I can do it. The
shortcuts above are based on the principles that anything XORed with
itself is zero, and anything XORed with zero is itself.
Steve
On 2 Mar 03 at 13:02, Jonathan Peakall wrote:
> Hi All,
> Well, got the oncore hooked up and catching satallites. Thanks
> Steve! The code below works fine. Problem is, I don't understand how
> the checksum values are created...
instead.
command:
shortcut.
Steve
> Hi All,
Well, got the oncore hooked up and catching satallites. Thanks Steve! The
code below works fine. Problem is, I don't understand how the checksum
values are created. They look like Greek to me! I looked in the data sheet,
and I can see that the checksum has something to do with the number of bits
returned for each command. A couple of examples are below.
' read date
checksum = "A"^"c"
SEROUT Gps_out,Bin_baud,[noparse][[/noparse]"@@Ac",$FF,$FF,$FF,$FF,checksum,CR,LF]
DEBUG CR,"Date: "
SERIN Gps_in,Bin_baud,[noparse][[/noparse]STR x\4,month,day,year.HIGHBYTE,year.LOWBYTE]
DEBUG DEC month,"/",DEC day,"/",DEC year
' read time
checksum = "A"^"a"^$FF
SEROUT Gps_out,Bin_baud,[noparse][[/noparse]"@@Aa",$FF,$FF,$FF,checksum,CR,LF]
DEBUG CR,"Time: "
SERIN Gps_in,Bin_baud,[noparse][[/noparse]STR x\4,hour,minute,second]
DEBUG DEC hour,":",DEC minute,":",DEC second
Can someone explain the checksum stuff to me? In small words?
Jonathan
www.madlabs.info
