Core Wars — Parallax Forums
Core Wars
edited 2003-03-02 00:29 in General Discussion
I don't know why I thought of this last night, but.....
In the ancient past, two competitors would write programs that
would flip a bit in the other guy's (gal's?) computer memory. The
two programs would take turns fighting it out. When the right bits
were flipped, the other guy's program would crash. As I understand
it, the two programs ran on the same computer and shared the
same memory. However, the location in memory of your progream
was unknown to your competitor, so it was similar to Battleship.
You just lobbed logic bombs into memory, trying to wipe out the
functioning of the other program.
I'm wondering if that can be done with the Basic Stamp. Can two
Basic Stamps be connected together and write to each other's
EEPROM? If not (and I think not), then can they share an
EEPROM and be programmed to read directions from the shared
EEPROM (similar to what Stamps do). In this case, the program
to read EEPROM and operate on the instructions is programmed
into each Stamp. The program has to be the same on both
Stamps. The program also has to signal the competing Stamp
when it is its turn. To start the match, a 555 would oscillate at
high frequency. A push button is released when the match is to
start. If the output is high when the button is released, then the
first Stamp begins the match. If low, then the second Stamp
begins the match. Since the 555 oscillates too fast for humans to
count, releasing the switch would be near random.
What do you think?
Paul
    You could simulate this game using only 1 Stamp connected to N switches
    (or a keypad). Two players would take turns flipping switches, or
    entering a keypad value. The program would first select random
    numerical values in the range 0 to 2**N, as the critical (crash) values.
    The first player to hit a critical value loses the game -- similar to
    Windows Minesweeper.
    Dennis
    From: verhap@o... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-pWbNjOza4ekJNouu8bBKAJfaLFlo0hhNuNMWhn2u4Lu2EZ_bAgl8n8SHvRqZCAq0jj0NqchKnp2DLoS6tEhilUdNss]verhap@o...[/url
    Sent: Saturday, March 01, 2003 2:57 PM
    Subject: [noparse][[/noparse]basicstamps] Core Wars
    What do you think?
    Paul
    Your use of Yahoo! Groups is subject to
