Radio data link.
Hello everyone,
I was looking for some information, advice and or suggestions...
I am using a basic stamp in a mobile robotics platform and wanted to
send information back from the Stamp to my host PC, but without wires!
My brother has just installed a wireless nextwork at his house and it
got me thinking. Could I get an RS-232 to ethernet(TCP/IP) converter?
This way I could plug the Stamp into my converter, that into a
wireless network point ---- radio data link
Wireless network
access point to a PC. And software converts the signal back to RS232
and allows me to access, as far as my PC thinks a real COM port.
Fairly straight forward so far...
I have found a converter and software that will allow me a "COM port"
on my PC that I can then use HyperTerminal to monitor and/or send
commands to the stamp remotely. Its 99GBP or about $156. Its not
cheap but it might just work....
My question is, am I looking at a nut and trying to crack it with a
sledgehammer?? Is there an easier way to do this because I cant help
thinking that I am overlooking a much easier (and cheaper!!)
option....
Has anyone done something similar but a different way?
Can anyone think of any problems I would have with my idea?
Any help would be greatfully appreachiated...
TIA,
Andy.
Wireless network
option....
TIA,
Andy.
>Hello everyone,
Wireless network
>option....
>TIA,
>Andy.
Hi Andy -
You might want to look into the possibility of using IrDA as a medium.
Here is an excellent link on using the Maxim MAX3100 for IrDA communications
with a Stamp: http://www.emesystems.com/BS2IrDA.htm .
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thanks for getting back to me.
I had thought about IrDA but had dismissed it with little real
knowledge about it, maybe to my downfall.
What is the suseptibility to different ambient light levels?
What happens if you don't have line of sight?
My TV remote is very twitchy if there is something in the way?
(Like the better half!!)
What kind of range could be expected?
Could you piggy back the transmitters and double the transmit
power or does it not work that way?
Thanks again for your help.
Andy.
--- In basicstamps@yahoogroups.com, Bruce Bates <bvbates@u...> wrote:
> At 11:59 AM 2/28/03 +0000, thor69uk <andrew.thornber@c...> wrote:
> >Hello everyone,
to
wires!
it
converter?
Wireless network
RS232
port"
help
> >option....
> >TIA,
> >Andy.
> Hi Andy -
medium.
communications
> Regards,
> Bruce Bates
Subject and
I use a pair of parallax transceivers and 2 BS2's. Works very good.
Stock#: 27997 433.92 MHz Transceiver
Jerry
IrDA is short range, because the carrier is not modulated. (Those
advertisements showing people syncing their Palms through the windows
of moving trains are a joke!)
A better option is the IRbuddy from Parallax or the IR products from
Rentron. They are long range infrared telemetry using a high
frequency carrier. No, the IR does not perform well outdoors or in
sunlight, although it does perform well under normal room lighting.
(photodiodes have a tremendous dynamic range, but sunlight swamps it.)
The 433 mhz radio modules are a good option too, with good range of a
couple hundred feet. These other modules connect from your PC
directly through the serial port.
I'm not sure what you would gain from your TCP/IP connection, but it
may be overkill unless you really do want the internet connectivity.
Be forwarned, the signals from the "cheap" systems are noisy, and
your software on both ends will have to take care of noise
suppression and error correction. Those are issues. If you use a
scheme like your bluetooth or whatever, the error correction would be
taken care of at a low protocol level, and your PC and your stamp
would see only clean data. Another option directly from the serial
port (not involving ethernet, TCP/IP etc) is a radio modem, such as
those offered by http://www.maxstream.net. Those have tremendous
range (much greater than bluetooth), and also they take care of all
the transmission packets internally, so, again, all your stamp or
your PC sees is clean data.
-- Tracy
>Bruce,
>Andy.
> > >Hello everyone,
>to
>wires!
>it
>converter?
Wireless network
>RS232
>port"
>help
> > >option....
> > >TIA,
> > >Andy.
> > Hi Andy -
>medium.
>communications
> > Regards,
> > Bruce Bates
>Subject and
>Subject and Body of the message will be ignored.
I have been experimenting with transferring data via RF (#27996 Tx to
#27995 Rx) and having mixed results. I built a circuit that is
commanded by a PC for the transmitted data. The receiver is plugged
into the stamp and am using Pulsin to collect PWM data. Could you
describe what type of data you are sending/receiving and also what
interface you may have between the tranceivers and the stamps. I
have had a terrible time and am interested in anything that works.
Al
--- In basicstamps@yahoogroups.com, CGIJERRY@A... wrote:
> Hi Andy,
> Jerry
