linearizing data
Hi all,
I am planning a project where I am going to read a non-linear transducer
via an A/D and then output a linearized value in engineering
units...perhaps to an LCD. After I hook up the transducer and record
10-20 data points, what is the best way to linearize the the input from my
A/D? Lookup table?
I am also looking for a 12 bit A/D that's easy to interface to a stamp. I
need something that I can use an external reference of 10 volts on. Any
suggestions?
So, my A/D counts will range from 0 to 4095 and my engineering units will
range from 0-200.0 (only 1 decimal place needed).
Aaron
A/D? Lookup table?
suggestions?
Aaron
that describes the output of the transducer vs its input? You may be able
to do a table lookup, then interpolation. It all depends on the shape of
the curve. What I do in cases like this is build an Excel spreadsheet and
examine the data to see if table lookup will work.
If not, then life gets messier. You need to use the transfer function of
the transducer, or, if that is to difficult to handle on a Stamp, a
polynomial approximation, which may also be too difficult to handle.
For example, if the transfer function of the transducer is y=a+bx^2, where
a and b are constants, and x is the transducer output, that's easy to handle.
However, if the function is y=a*x^1.236, that's a bit harder ( a LOT
harder!) - table lookup with interpolation or a polynomial approximation is
needed. Your accuracy requirements will determine what you can get away
with. If 10% is OK, then life is sweet. If 0.1% is needed, you are in trouble.
Tracy Allen's web site has a lot of useful Stamp math stuff, in particular,
the use of the ** operator to work with fractions.
Also, Al Williams site has a floating point "co-processor" for use with the
Stamp. Using it, processing the transfer function should be easy.
Now, your A/D converter - there are, at a conservative estimate, 10^6 A/D
converters on the market. You need one that has a serial interface - there
are piles of them. Check the Maxim, Linear Technology, Analog Devices and
National Semiconductor web sites and start searching for devices that will
meet your requirements. The 10v external reference may be difficult to
handle. The A/D's I've used typically are designed for 5 volts, and either
have a built-in reference or let you supply your own, up to 5 volts. But
search the web sites - you may find something.
But why do you need a 10 v reference? Can you not scale down the output of
your transducer into the range of 0 to 4 or 5 volts? Then there are a LOT
of A/D converters available.
Larry
At 09:22 PM 2/27/2003 -0500, you wrote:
>Hi all,
>A/D? Lookup table?
>suggestions?
>Thanks,
>Aaron
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Larry Bradley
Orleans (Ottawa), Ontario, CANADA
routine -- it's acurate to at least 0.0X places and can be found at
www.emesys.com I use a variation in a densitometer.
if the data require manipulation, higher math, statistical analysis,
consider using StampDAQ which Martin Hebel wrote for Parallax -- it's
a free download -- takes your values and puts them right into an Excel
spreadsheet.
and you might want to just surrender and use the BX24 from Netmedia --
same 24 pin DIP as a stamp, same pinouts -- has a wealth of fixed and
floating math functions. The language is akin to VB so it's not
difficult to learn.
--- In basicstamps@yahoogroups.com, Larry Bradley <lhbradley@i...> wrote:
> The answer to that question is "it depends". What is the transfer
function
able
shape of
spreadsheet and
function of
where
to handle.
approximation is
in trouble.
particular,
with the
10^6 A/D
there
Devices and
that will
either
But
output of
a LOT
> Larry
> >Hi all,
transducer
from my
> >A/D? Lookup table?
stamp. I
Any
> >suggestions?
units will
> >Thanks,
> >Aaron
Subject and
> Larry Bradley
