Driving LCD with I2C I/O expander (PCF8574) — Parallax Forums
edited 2003-02-27 13:04 in General Discussion
Does anyone know if it is possible to drive LCD (in 4 bit mode) via
PCF8574 (8 bit i2c i/o expander) so that PCF8574 drives 4 bits for
data, RS, R/W and E?
I've been successful in using PCF8574 to drive the 4 bits for data,
RS and R/W, but not E. I have to use a Stamp port to drive the E
signal.
Has anyone some knowledge if this is even possible?
I've read that internal structure of the PCF8574 is a shift register.
I think this may be the problem (i.e. I cannot obtain a clean High to
Low signal for E via PCF8574).
If anyone has some info., I would really appreciate it.
Happy stamping to y'all...
    edited 2003-02-26 23:04
    Dont know if this has anything to do with it but, the PCF8574 is fine for
    sinking power (enough for logic at least) but has virtually no sourcing
    capability (25ma sink but only 300uA source per pin if I remember
    correctly). Might you be overloading its output capability and dropping
    voltage below what the LCD can read?
    If this is the problem (and it may well not be!) the 74HC595 might be a good
    replacement. More I/O pins needed on the stamp. The other possibility would
    be to feed the 8574 outputs to a transciever chip like the 74xx244 or 245
    and let them source the LCD.
    I'm a newb shooting in the dark though so don't take my word as gospel.
    My 'lectronic Newb site http://members.shaw.ca/pmeloy/
    Sent: Wednesday, February 26, 2003 1:28 PM
    Subject: [noparse][[/noparse]basicstamps] Driving LCD with I2C I/O expander (PCF8574)
    > signal.
    Hi there. It's a general characteristic of TTL logic (and possibly
    other types) that they sink well, but don't source well.
    ARRL Handbook, 2002 (by the way, these are great sources of general
    electronic information and sometimes available at the local library),
    74HC series Max clock frequency 30 MHz, output sink 8 mA. It doesn't
    list the source current, but I would guess it to be less than 0.5 mA.
    From: Pat M [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=us-oUePKtC9EqpWyUkZD2ViZNLqqwLPvYqNonKXcEA8IpvQVAojZCNrLRq5jUshOUxtNDg]pmeloy@s...[/url
    Sent: Wednesday, February 26, 2003 6:05 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Driving LCD with I2C I/O expander (PCF8574)
    for sinking power (enough for logic at least) but has virtually no
    sourcing capability (25ma sink but only 300uA source per pin if I
    remember correctly). Might you be overloading its output capability and
    dropping voltage below what the LCD can read?
    good replacement. More I/O pins needed on the stamp. The other
    possibility would be to feed the 8574 outputs to a transciever chip like
    the 74xx244 or 245 and let them source the LCD.
    > I've been successful in using PCF8574 to drive the 4 bits for data, RS
    > and R/W, but not E. I have to use a Stamp port to drive the E signal.
    > and
